Posts: 3241 Joined: 26 Jun 2007, 13:58
Been thanked: 112 times
Post
by analogguru » 01 Apr 2009, 00:01
Do you mean how to build a clone of this ?:
Thats very easy, as you can see here:
borislavgajic
Posts: 1542 Joined: 27 Feb 2008, 14:23
Completed builds: ...script phase90,ETI phaser,Ross phaser,mutronC200,vox wah,WH10,FW-3,mutronIII,DrQuack,Penfoldautowah,Tubezipper, Dipthonizer,seekwah,Talkingpedal,morleywha ...soulpreacher,dynacomp,compulator ...buzzaround,fuzzfactory,screwdriver,sho,superdouper,St-9,RogerMayer octavia,Tychobrahe octavia,paralelluniverse,string damper,slowgear ...CE-2,ibanez fL301,EH theCloneTheory EHX bassmicrosynth,EHX EnglishMuffin,Tube Phaser,springtubereverb ,greyDOD,FulldriveII mosfet,OCD,VOX repeat percussion,RingStinger,Meatball,12stage phaser....
Has thanked: 132 times
Been thanked: 255 times
Post
by borislavgajic » 02 Apr 2009, 10:30
pictures are nice nice nice!!! thanks..........
borislavgajic
Post
by borislavgajic » 02 Apr 2009, 11:07
jrod
Posts: 406 Joined: 09 Jan 2009, 14:24
Has thanked: 343 times
Been thanked: 41 times
Post
by jrod » 02 Apr 2009, 13:55
What are the pictures of that AG posted? Colorsound One-Knob Fuzz?
Post
by analogguru » 02 Apr 2009, 21:15
jrod wrote: What are the pictures of that AG posted? Colorsound One-Knob Fuzz?
The first picture is from a Colorsound (One-Knob) Fuzz Box Reissue from 1996:
The other three pictures are from a clone-pcb of that unit - built by me.
Posts: 4882 Joined: 09 Jan 2008, 06:02
Has thanked: 144 times
Been thanked: 138 times
Post
by RnFR » 02 Apr 2009, 21:37
Blog-
APOCALYPSE AUDIO
Fuzzed
Posts: 38 Joined: 02 Apr 2009, 12:26
Post
by Fuzzed » 02 Apr 2009, 23:24
analogguru wrote: Do you mean how to build a clone of this ?:
THAT LOOKS ADORABLE!
Electric Warrior
Posts: 735 Joined: 23 Feb 2009, 03:37
Has thanked: 23 times
Been thanked: 97 times
Post
by Electric Warrior » 04 Apr 2009, 01:51
some time ago I made a vero layout based on AG's pics and Stu's schematic. hope it works, haven't tried it yet.
patafix
Posts: 84 Joined: 16 Jan 2008, 11:21
Been thanked: 2 times
Post
by patafix » 08 Apr 2009, 10:21
The versions posted (reissue and clone) look different.
The reissue version has 3 transistors, the clone has two... so what's the 3 transisor for ? Added gain stage? buffer ? Mill Bypass ?
Patafix... so sticky
patafix
Post
by patafix » 08 Apr 2009, 12:44
So this circuit has a fuzz face topology... with the gain knob omitted (maxed out all the time) and slightly tweaked values for the components.
patafix
Post
by patafix » 08 Apr 2009, 19:10
But I still don't know why the colorsound reissue has 3 transistors, diodes etc...
Post
by RnFR » 08 Apr 2009, 19:55
i was under the impression that this was a vintage release, hence the categorization. is it true that this design was only released within the last decade?
Blog-
APOCALYPSE AUDIO
Bernardduur
Posts: 1150 Joined: 24 Aug 2007, 07:36
Has thanked: 87 times
Been thanked: 517 times
Post
by Bernardduur » 09 Apr 2009, 08:05
Is it really a clean blend feature?
'a little preset wheel that allows you to balance the effected sound against your true bypassed sound'
I could also interpret that as a volume control; then maybe the 22k lin pot does something else (like gain or pre-volume or something like that).
Great pedal! I once build one in a Colorsound Fuzz Wah pedal of which the fuzz was removed from.
Post
by analogguru » 09 Apr 2009, 18:59
No, it is NOT the same, it is similar....
one big difference is the collector resistor of 4k7 at the second transistor in the Jennings pedal(s) instead of 2k2 in the colorsound pedal.
The Jennings Fuzz-circuit was also used in the Cyclone.
At least in the cyclone the 220n output cap is loaded with 100k (instead of 470k used in the colorsound pedal).
Electric Warrior
Post
by Electric Warrior » 09 Apr 2009, 21:34
thanks for clearing that up!
Mr. G.
Posts: 384 Joined: 03 Jul 2008, 19:32
my favorite amplifier: Undecided
Completed builds: 3-loop + tuner out TB loop pedal Eternity overdrive (Deaj perf layout) YATS (many) BOR DLS COT (Briggs mods) Crunchbox SHO (several) Fuzz Factory Several LM386 based distortions
Has thanked: 1 time
Been thanked: 8 times
Post
by Mr. G. » 17 Apr 2009, 15:47
Anybody tried anything like 2N5089/5088 in this pedal?
I ask because I only have some BC108's, and no BC109's at the moment.
Any other transistors that might sound good in this circuit?
