Sola Sound - Tonebender MkIII  [schematic]
beedotman
Has thanked: 402 times
Been thanked: 394 times
Post by beedotman »
thanks!
Electric Warrior
Has thanked: 23 times
Been thanked: 104 times
Post by Electric Warrior »
Here's a schematic of the '72 to '76 version:
As I mentioned earlier, these came in a number of different enclosures. The most common variant is the silver and orange (or rarely yellow and black) "batman logo" Tone Bender enclosure. The Vox MKIII, Park Fuzz Sound, Carlsbro Fuzz and CSL Super Fuzz branded versions are not quite as common.
jimmybjj
Been thanked: 11 times
Post by jimmybjj »
I made this layout to use some of my low gain transistors. I used a ge transistor for the diode on Q3. Don't forget the jumper next to the diode, or under if your using a transistor. On board charge pump so you can use your regular 9v adapters. I am 99.9% sure this is verified. I built one but had a error in the layout and i fixed it, and adjusted the layout, hence the jumper. Works well.
Layout Here
This board is in the style of John Lyons :)
bigmufffuzzwizz
my favorite amplifier: 1973 Sunn Model T
Post by bigmufffuzzwizz »
Awesome layout Jimmy!
I learned so much just from this thread, falling into a fuzzz fever... :D
I've also been wanting to build a sili tonebender like the one on Basic Audios site for awhile now.
Magic Pedals Home of The Shrine Fuzz!
Been thanked: 909 times
My bud asked me to do this, after hi scored one of these mkiii boards from Peps! (pigeon FX)
Two versions are attached
- ordinary mkiii
- 2knob fuzz sound mkiii
Just component names on PCB + matched component names on schematic. Use your favorite set - good source is this tread, or Fuzzcentral.
On my layout ins/outs are other (right) way around. In England even pedals are left side driven :blackeye
Only PDF's
damn, mkiii ones again. accidentally I've uploaded 2knobers twice
beedotman
Post by beedotman »
Great work, Sinner! :thumbsup
I'm on it right now
I decide to test the dodes (1n34a) I've scored years ago from banzai music, and they all tests 0,62 to over 0,7vf, like the silicons... WTF? they should test half of that... Does it means I can't use that in mk3?
I can't find the rest of my diode stash :roll:
Electric Warrior
Just use a leaky germanium transistor.
was it collector (anode) an base?
I was able to find some black glass 1n60's with 0,3fv finally
Electric Warrior
Base and emitter. Not sure which is anode, but you'll know when it's wrong.
LucifersTrip
my favorite amplifier: Companion Psychedelic Machine
Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
Has thanked: 19 times
Been thanked: 71 times
Post by LucifersTrip »
sinner wrote:was it collector (anode) an base?
that's funny...all my glass case 1N60's from the 1960's measure ~ .6v
LucifersTrip
Electric Warrior wrote:Base and emitter. Not sure which is anode, but you'll know when it's wrong.
you can use either base/emitter or base/collector
for pnp, emitter & collector are anode. base is cathode
for npn, base is anode. emitter & collector are cathode
funny, I just posted a pic of this on the DAM forum...my DOA bag of vintage transistors with too low gain, too high leakage, a short between lugs or a lug broken off...which I use for diodes
Electric Warrior
LucifersTrip wrote: you can use either base/emitter or base/collector
Yes, but base and emitter is what Sola Sound used.
I left 1N60 in, it tests right
Anyway, I'm stuck, as I have no any 20mm pots (omegs), as well as no styroflex caps of 220p/2n2 value
I decided to go with repro board from Brook this time, and with new production parts all the way - last time I was using new type of components was like 2 years ago :))))
So - orange Phillps caps (thanks B.man), and BC e-caps, and Dale CCF60 resistors (awesome resistors)
One resistor, the one between tone pot and volume was jumpered under the pot (common, anti-volume-drop mod)
transistors are the only NOS components, I've used Hitachi 2SB75's, not as fancy as some Mullards, but the gain/leakage buckets was what I was looking at
Two in darlington pair tests the same 55hfe/0,06leak, and 92hfe/0,19leak for Q3
I wanted to have leaky Q3 transistor as it's always sounds best to my ears if it's leaky, sometimes 1mega resistor between base and colletor helps if it's not...
Like I said, no pots right now, so I have to wait till they arrive
beedotman
Post by beedotman »
wow! sexy stuff!
:thumbsup
Electric Warrior
76µA is leaky these days? What happened? :mrgreen:
LucifersTrip
Electric Warrior wrote:76µA is leaky these days? What happened? :mrgreen:
I assumed he gave leakage in mA, not voltage....so 190uA? which is still not really leaky. I used leakage ~250-300uA in similar circuits.
Electric Warrior
I assumed 0,19 would be the reading on a multimeter with an RG style hfe tester circuit.
peak dca55.
Imo 0,19 is planty for mk3, i can always short collector and base with an resistor
