JMI Vox - Grey Wah c. 1967
Has thanked: 890 times
Been thanked: 703 times
Can you also confirm the wiring diagram while we at it? :)
http://www.turretboard.org/?p=30
deltafred
Has thanked: 320 times
Been thanked: 204 times
Post by deltafred »
It's an age thing, I know another guy with a 40 year old Wha pedal that he has had form new.
I will hang on to it for a bit longer and do you a full drawing of the board, that bit is easy.
I don't mind pulling the transistors out to measure them and I was going to measure the resistance and inductance of the inductor anyway.
Inductor 297mH - measured on a cheap DMM model no VC9808+ make unknown.
DC resistance 16.6 ohms (measured on 2 different DMMs).
I'll email you a zip of all the photos I take. It might not be immediately as I am away quite a bit in the near future.
deltafred
Post by deltafred »
sinner wrote:Can you also confirm the wiring diagram while we at it? :)
Yep, will do when I get chance.
Both Q1 and Q2 hfe around 410 measured on 2 different crappy little DMMs. This varies with temperature so no point being too precise.
410hfe? twice as much as I was thinking... thanks :)
Also thanks for the rest, I had two another 300mH readings from my website visitors, but never the resistance...
You don't have to draw new template with board dimensions, I already did it, just look on it (it's on my website) and check against yours :)
Pawel
deltafred
Post by deltafred »
There is a missing link under the perf board. I have shown it above the resistors for clarity.
deltafred
Post by deltafred »
Sinner
A very minor point.
The row of component holes are 0.5" apart not 0.45" as you have them. (I said it was a minor point).
The board is mounted by 2 self tapping screws (1/2" x 1/8" approx), on 2 paxolin tube spacers 1/4" long.
Got the jumper fixed
I had it there in first version, but I've screwed making revision :oops:
Thanks a lot
Rjcastro76
my favorite amplifier: Marshall Jtm45
Completed builds: Dallas Rangemaster, Germanium fuzz face, Silicon fuzz face, Big Muff mods
Post by Rjcastro76 »
Would 2 500mh inductors in parallel be similar to one 250 mh inductor? I understand the would have to be somewhat separated to shield the magnetic field....
Rjcastro76 wrote:Would 2 500mh inductors in parallel be similar to one 250 mh inductor? I understand the would have to be somewhat separated to shield the magnetic field....
May be similar, but not exactly the same thing. Grey Wah Wah inductor use smaller diameter coil and different wire diameter. Inductor resistance will be off
Rjcastro76
Ok, I guess I'll try to get a 250mh one. Also, on turretboard.org, are both layouts for the grey wah correct? If not, which is? The top, or bottom one? Thanks
Rjcastro76 wrote:Ok, I guess I'll try to get a 250mh one. Also, on turretboard.org, are both layouts for the grey wah correct? If not, which is? The top, or bottom one? Thanks
AFAIK they are correct. True to the schematic at least
Lucifer
my favorite amplifier: Vyse BBQ Blue
Has thanked: 66 times
Been thanked: 67 times
Post by Lucifer »
Hey Sinner - is that really you in the photo ?
Wow, you never told us you were so handsome !
Dude, its Andy Pipkin ;-)
Lucifer
Post by Lucifer »
I know, dude !
But if it was you, you'd still be a gorgeous bastard !
Yeah, I know ;-)
PurpleOhmAudio
Post by PurpleOhmAudio »
Hi, sorry to drag this old thread up but does anyone know the actual board dimensions in these old Grey Wahs?
As deltafred mentions the component holes are 0.5" apart, and the tube spacers paxolin, so I presume the board will be, and looks to be just 1mm thick.
I have a few of the same enclosures from the corresponding volume pedals, one with the Vox logo on the casting, one is plain without logo but has the exact casting marks and imperfections etc,so in theory from the same place...
Got them on ebay, one was quite badly butchered (annoying the one with the Vox logo :x ), there was a DIN socket hole in the side (maybe for multi channel volume?] and put a spring and momentary switch inside, very strange....
Was going to build them into clones and get them going again, just need to get a few parts sourced, might even go crazy and goop the board too, might stop the mojo leaking out
On another note, does anyone know if there is a axle tension bar under the treadle on the original 'Grey Wahs', as these volume pedals do not, and seem to rely only on the pot friction, cant find any pictures that show it online, but it looks like originally there was a battery clip which may bolt through to the other side?
nightraven
Has thanked: 15 times
Been thanked: 71 times
Post by nightraven »
PurpleOhmAudio wrote: On another note, does anyone know if there is a axle tension bar under the treadle on the original 'Grey Wahs', as these volume pedals do not, and seem to rely only on the pot friction, cant find any pictures that show it online, but it looks like originally there was a battery clip which may bolt through to the other side?
Yeah, you're quite right, they wedged a battery clip upside down against the 'gear' of the pot assembly, to help keep it in place. Not only do the Selmer and JHS wah pedals from the 1960s seem to have enclosures cast from the same mould as well, they also have this upside-down battery clip thing going on as well.
Has thanked: 3181 times
Been thanked: 659 times
sinner wrote:
06 Mar 2010, 17:40
Here's some info about components used http://wah-wah.co.uk/greyvox.html
Dan N wrote:
08 Mar 2010, 21:19
The Thomas Organ part # for a 250mh inductor is 80-5044-7. Organ Service Corp. ( http://www.organservice.com/ ) have them on their stock list for $8.00. I don't know exactly what OSC stocks, but they replace a brown TDK in a Fasel style package.
I attached archived pdf and xls files to above messages -- both websites are down. You can jump to these posts using the arrows next to the username of the quote.
this one too...
