My New Legacy 5 Watt Class A Valve Guitar Amplifier
- DrNomis
- Has thanked: 98 times
- Been thanked: 279 times
Hi friends,
I just scored myself this Legacy 5 Watt Class A Valve Guitar Amp from Billy Hyde Music, it normally retails for Aus $399.00, I got it for just Aus $150.00, why?, because the fuse holders are broken and I told the Shop Assistants at Billy Hyde Music that I could fix it myself, they had a talk amongst themselves and agreed to sell it to me for Aus $150.00...good score or what?......
Here's a pic of the Amplifier:
- DrNomis
Does anyone know where I can find a schematic or service manual for this?, any help muchly appreciated as I really want to get it going.....
- SirElwood
That looks like epiphone valve special amplifier. http://www.zzounds.com/item--EPIEPABKSPDSP
If so, here is the schematic.
- marmaliser
Nice score
EDIT - TOO SLOW It looks like a rebadged epiphone Valve Standard / Special so I would start your search there. If you can not find one contact Gibson, I believe they will supply them
- SirElwood
That is indeed a nice score. Lots of potential in these amps. Valve jr. was some time ago very popular and people modded a hell out of those. Special/standard has some crappy effects and if you bypass those you get nice amplifier. And there is extra potentiometer holes you can use something usefull like tremolo or something. Might be a fun project.
- DrNomis
marmaliser wrote:Nice score
Thank you so much marmaliser, don't feel too bad about that, the info you've given me is actually alot of help...cheers...
Might post some gutshots of the amp chassis.....
I mostly need to see how the three fuses are wired so I can replace the three broken fuse holders.....
- DrNomis
SirElwood wrote:That is indeed a nice score. Lots of potential in these amps. Valve jr. was some time ago very popular and people modded a hell out of those. Special/standard has some crappy effects and if you bypass those you get nice amplifier. And there is extra potentiometer holes you can use something usefull like tremolo or something. Might be a fun project.
Cool...cheers....
Want me to post some gutshots of the chassis?.....
- SirElwood
Well... I have seen enough of those... But it can't hurt if you do so. It might help some other people in the future.DrNomis wrote:Want me to post some gutshots of the chassis?.....
- DrNomis
SirElwood wrote:Well... I have seen enough of those... But it can't hurt if you do so. It might help some other people in the future.DrNomis wrote:Want me to post some gutshots of the chassis?.....
Okay....
- DrNomis
SirElwood wrote:That looks like epiphone valve special amplifier. http://www.zzounds.com/item--EPIEPABKSPDSP
That Epiphone Valve Special amp looks awfully similar to my amp, same control layouts too....
- DrNomis
Valve line-up in my amp is x2 Chinese 12AX7B preamp tubes and x1 Sovtek EL84/6BQ5 power tube....
- DrNomis
Okay, I have fixed the amp and it's working well, a slight bit of background hum but apart from that, no other issues, the amp sounds a little dark, probably because my Ibanez guitar is a bit dark sounding, but I'm able to get a useable clean sound out of it, and an interesting overdriven sound out of the amp, but set the amp for a clean sound and use Bajaman's Baja Real Tube Overdrive pedal with it and you have some nice Rock sounds remeniscent of a Marshall, the onboard DSP FX arent that crash hot, most useable seems to be the delay effects, on the otherhand, the reverb is very useable and adds depth to the sound of the amp, I'm really liking the amp.....
- marmaliser
This any help for your HUM
http://music-electronics-forum.com/t3020/
BTW Taking an interest in this as I have just finished modding a Valve junior which now sounds a lot better now
- DrNomis
marmaliser wrote:This any help for your HUM
Oh cheers mate....
- DrNomis
Here's something I've just discovered, if you want to use the amp's basic overdrive, but want more gain, try using a Timmy to overdrive it more, the bass cut control really gets rid of any tendency for flabbiness....
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
far too many controls for a 5 watt amp
- DrNomis
bajaman wrote:far too many controls for a 5 watt amp
I totally agree bajaman, and far too many controls for simple old me...rofl...sorry couldn't resist a little self-deprecation, at my own expense....
I tried your Real Tube Overdrive pedal through it and it sounds great....
- DeanM
Wow, really? you just discovered using a pedal as a booster?DrNomis wrote:Here's something I've just discovered, if you want to use the amp's basic overdrive, but want more gain, try using a Timmy to overdrive it more
thats almost signature worthy stuff there! lol
- DrNomis
DeanM wrote:Wow, really? you just discovered using a pedal as a booster?DrNomis wrote:Here's something I've just discovered, if you want to use the amp's basic overdrive, but want more gain, try using a Timmy to overdrive it more
Lol....yeah I know....
- DrNomis
Sorry for my abscence, anyway, it turns out that my Legacy Valve Edition 5 Plus amp is indeed an Epiphone Valve Special Combo, it says so on the PCB, basically it has been re-badged as a Legacy amp, I did some mods to the power supply, removed all the stock 22uF/450V caps, and replaced two of them with a 100uF/400V, and the other two with a 47uF/450V cap, result, it's much quieter, no annoying background hum when the HT standby switch is switched to "play"...
