Here's the vero - verified and all...
Runoffgroove - Ruby Amp
- grrrunge
I whipped up a vero for the ROG Ruby amp tonight - thought i might give it a go, though it's maybe not as compact as i could be. It sounds pretty nice, and is supposed to go in a cardboard box along with a speaker i salvaged from an old tv
I built mine with a 2N5457. J201's work fine as well.
- sinner
- Has thanked: 1031 times
- Been thanked: 907 times
I may give it a go. I have two tinny speakers saved from my old, crashed mac. It will sound geeky with those speakers, but hell... why not
- grrrunge
I decided that i liked this one enough to try and compact the layout a bit. It's not verified yet, but should be accurate
Here you go:
- geiristudio
Which ohm speakers can you connect to this ?
- rizibiz
Here is my (VERIFIED) version of the one knob Bassman modded Ruby Amp
Sorry for the lots of jumpers and the jumper crossing. I really wanted to make it as small as possible.
Fits nicely in a 1590A
I built this last week and used a 8ohm 12" 70W speaker for it. It sounds okay to me.
First post BTW (thank you for all the knowledge here).
- kleuck
Just a suggestion : put a 1 watts resistor of 1/4 the impedance of your speaker, in series in the output.
Randall Aïken said :
- rizibiz
kleuck, I'll try it on the weekend. What does this exactly do?kleuck wrote:Just a suggestion : put a 1 watts resistor of 1/4 the impedance of your speaker, in series in the output.
For those who are interested pics of my build:
- kleuck
I don't want to spoil, it's an experiment, i hear a big difference, want to know if someone else hears the same.
I tried with a true guitar cab (and that's the point...somewhat) so if anybody is willing to make the resistor switchable (just short it) and test with a good cab....
Actually i used a LM380, but doesn't matter.
Tiny built
I make a buffer in this enclosure :
Tiny built
- rizibiz
Allright then, I still have a free DPDT switch next to my pot.
That was used to switch the 220pF cap on the volume lug but I didn't notice any difference so I finally left out entirely.
Anyways I breadboarded the original two knob Ruby and this 'Bassman' modded one and liked the later better with my Strat. Still somewhat sterile but I don't expect too much from such a low cost low part count build. Btw I drived a real 12" guitar cab with it. Plenty of volume for apartment practice.
Nice brushed enclosure kleuck. Love it.
- kleuck
Well, not really brushed...
- grrrunge
That buffer looks good!kleuck wrote:I don't want to spoil, it's an experiment, i hear a big difference, want to know if someone else hears the same.
Tiny built
- kleuck
Thanks guys ! Hope you will hear something interesting (BTW, a 1/4 watts should be fine actually, i used a 1 watt one as the LM380 is a 2 watts IC, not useful with a 386)
- kleuck
So, did you hear something ?
- grrrunge
I haven't tried it yet, but i'm still excited to do so. Gotta get me som more free timekleuck wrote:So, did you hear something ?
- rizibiz
I'm going to be honest. I didn't.kleuck wrote:So, did you hear something ?
I ran it through my 12" 70W guitar speaker 1x12 cab but no noticeable difference for me with or without the resistor.
- kleuck
Shit, anyway i used a 1 ohms for a 3 ohms speaker, more obvious result i suppose, i'm gonna make a little TBA820M amp and give it a try with different resistors.
