Amp Stand
Lucifer
my favorite amplifier: Vyse BBQ Blue
Has thanked: 89 times
Been thanked: 72 times
Post by Lucifer »
While working on a recently-acquired Fender Super Champ, I decided I could do with a stand to support the amp, and this is what I came up with.
It has three identically shaped pieces of 18mm pine (from a shelf), and three equal lengths of 25mm dowel rod. The two end cheeks are screwed onto the dowels, while the third piece has 25mm holes and can be moved along the dowels to accommodate whatever amp I may be working on. I made the whole thing wide enough to hold the biggest amp in my arsenal. A few strips of foam provide cushioning for the amp, especially for the face.
The pine pieces are shaped with a 60 degree slope, and rounded corners, so that the whole assembly can be tipped forward, enabling easy access to the innards of the amp.
As you can see from the attached pictures, the weight of the amp holds it in place, even when tipped forward. That's because the centre of gravity (thanks to the transformers) remains within the footprint of the stand.
And when not in use, the thing can stand on its end in a corner somewhere.
Cub
Has thanked: 97 times
Been thanked: 114 times
Post by Cub »
Brilliant ! I've been using the Swanson Amp Cradle since forever.
Changing work-angles is much quicker in your invention. :applause:
rocklander
Has thanked: 1404 times
Been thanked: 227 times
Post by rocklander »
that really is a freaking awesome idea... :applause:
Lucifer
Post by Lucifer »
Thanks for your kind comments guys.
A great deal of thought went into the design before I arrived at the final, simple layout (simple is best) - and it only cost me about £10 in materials.
The hardest part was finding a dowel size to match my available drills. I only found ONE DIY store that did 25mm dowel - Wickes (in the UK). Individually, the holes are slightly oversize, but there's enough friction across the three holes to keep the movable piece rock steady under the amp. Also, having three dowels instead of two makes the whole structure very stable.
Today I can get back to work on the amp - replacing the existing switch with a Carling "Off-Standby-On" switch.
iq01221
Has thanked: 31 times
Been thanked: 8 times
Post by iq01221 »
A very nice idea, man!!
I don't know if I'd use it live, could be a little dangerous... [smilie=new_tomato.gif]
blackbunny
my favorite amplifier: Fender Blackface
Completed builds: Lots of mods to lots of pedals
Has thanked: 271 times
Been thanked: 105 times
Post by blackbunny »
Devilishly clever, Lucifer! This is a "must build". :applause:
Lucifer
Post by Lucifer »
iq01221 wrote:I don't know if I'd use it live, could be a little dangerous... [smilie=new_tomato.gif]
Nice one IQ. Should be safe to use live, as long as you don't try to pee on it ! :twisted:
Lucifer
Post by Lucifer »
By the way, if anyone wants dimensions, etc. just let me know.
It's about so big :applause:
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
Really cool idea Lucifer, I might have to build myself one, since I'm into amp-building myself, my current (no pun intended) method of supporting an amp-chassis involves the use of suitably-sized books/boxes/anything else to-hand.... :thumbsup
Cheers for posting this.... :thumbsup
Lucifer
Post by Lucifer »
Hi Doc,
I was using a couple of boxes to support the amp initially, but they just weren't reliable enough - one slight nudge and they'd start to lean outwards, leaving the amp in a precarious position. That's why I decided to build something a bit better.
I'm pleased with the design, and chuffed that so many others (including your good self, sir) like it too.
As mentioned previously, if you want the dimensions, just let me know (although you can get a pretty good estimate just by looking at the pics).
Lucifer
Post by Lucifer »
The stand can be used for pedals too - of all sizes - the photos show a 1590B (COD) and a 1590DD (Super-Hoochie . . .).
Even on a 60 degree tilt, the pedals sit securely, allowing great access for a soldering iron or for test probes.
Amp Stand 13.jpg (63.23 KiB) Viewed 1900 times
Lucifer
Post by Lucifer »
And when it's not in use for the above tasks, it can serve as a display stand, or even a book case.
Any other (polite) suggestions welcomed.
Ben N
Has thanked: 167 times
Been thanked: 50 times
Post by Ben N »
Brilliant! I've been thinking about making something like that for years, but yours is simpler and better than anything that never made it off my drawing board. (I was thinking about a frame within a frame, with a kind of spit and clamps for rotating.) You should post is an eHow or DIYable.
ppluis0
Has thanked: 121 times
Been thanked: 278 times
Post by ppluis0 »
Nice work Lucifer...!!!
Can you post a drawing of the main wood pieces with their dimensions ? It will be useful for those of us that wish to build this same kind of tool.
Pruttelherrie
Has thanked: 45 times
Been thanked: 96 times
Post by Pruttelherrie »
This is mine:
It's not as easy as yours: mine takes a few minutes to configure for the amp, but since I have only a few amps to mod/repair per year that's ok. It took about ten minutes to build (forstner bits FTW!). Before that I used books and boxes, but that's pretty unstable indeed!
Pruttelherrie
Oh you could use yours as a footrest, too!
Lucifer
Post by Lucifer »
For those of you who kindly requested the measurements (and for anyone else who might be interested), here is the template for my Amp Stand.
Best regards,
Lucifer
Lucifer
Post by Lucifer »
Pruttelherrie wrote:This is mine:
Hi Pruttelherrie - your design looks pretty much like how mine started out. I like your locking screws - great idea. It looks like it'll handle a wide range of amps.
I like your suggestion of using mine for a footrest - but I fell off the workbench when I tried to take a photo of my feet in the stand :twisted:
ppluis0
Post by ppluis0 »
Thank you for post the drawing of the wood pieces !!!!!
(And i'm glad to see its dimensions expressed in millimeters... :mrgreen: )
BTW: how long ago the British were forced to adopt the decimal measurement system ?
Thank you again,
rocklander
the pics of it as a pedal stand are great. you inspired me to have a go (some time) at making a smaller version for my pedals. my workspace doesn't have the real estate to handle a full size one (well it does, but I have so much crap on there it doesn't now :blackeye ) so will be looking to make one to the max size of a 1590bb
:thumbsup
