Can you tell me, is this scheme right for making preamp or not?
Maybe there is some fresh scheme? Who was trying this?
Re: #34/#36/#39 scheme
Posted: 25 Sep 2015, 07:03
by apollomusicservice
The schematic is ok but there are a lot of things between rows when you building tube preamps.
Here is very dangerous high voltage and selection of components is very important.
Are you already made something with tubes?
Posted: 25 Sep 2015, 19:42
by alexhangman
apollomusicservice wrote:The schematic is ok but there are a lot of things between rows when you building tube preamps.
No, but my friend can, he made a lot of preamp for sale. He will do it, but i want to be sure that this schem is working. Because i found it from internet and i don't know is it working well or not.
We're gonna make the preamp and i will use it right through my power amp of Marshall JCM Slash jubilee 2555SL. What do you think?
Posted: 26 Sep 2015, 07:14
Great amp with built in two channels, clean and distorted. Your friend, who has a lot of experience,
will certainly recognize that schematic is ok. Go ahead guys and share with us yours working progress.
Posted: 26 Sep 2015, 08:40
by alexhangman
apollomusicservice wrote:Great amp with built in two channels, clean and distorted. Your friend, who has a lot of experience,
He said the schem is working, but i just can't decide what schem is better because there is a lot of schems, Duke amps schem and Shenier amps schem, candy fx... a lot of people do this mods with a different schems.
Btw is it ok that we will making just preamp without power amp, and i'm gonna put it to return of my JCM Slash 2555jubilee? Or it needs to make full amp 'cos power amp is modding too?
How will this affect on tone? Can i reach the Slash's tone with only preamp modding?
Posted: 26 Sep 2015, 11:10
by phatt
A quick look at the Amp circuit you mention tells me you are heading for a disaster.
If I'm looking at the right schematic the Fx loop returns to another triode stage and then the tone tree then into PI and power tubes.
The result will likely be buzz, hum, crackle and a lot of squeal if you try to turn up the volume.
You can get extra crunch and gain easy with a pedals but a lot of guys shun pedals.
Don't be fooled by hype there are many ways to get the same sound and many of those will likely be cheaper and easier to attain.
Phil.
Posted: 26 Sep 2015, 13:14
by alexhangman
phatt wrote:A quick look at the Amp circuit you mention tells me you are heading for a disaster.
Phil.
What circuit do you mean? Circuit of my 2555 jubilee or circuit of the schem in the first post?
Posted: 26 Sep 2015, 18:14
by alexhangman
I have one more amp, AFD100, there is a correct loop, right to the power amp. I can use it with that preamp.
If that is your Amplifier then you will likely run into problems as the preamp you have will unlikely give you the same sound with more gain.
You can't just keep adding gain stages,, YES a fair bet that the tone will be different and Murphy's Law suggests in a bad way.
Please Note;
You said you have a 2555 Marshall Amp head Slash model.
Now you want to build a separate preamp to get Slash's tone.
I'm sorry but that logic does not compute
yes if the other amplifier's efx return goes direct to PI then it will work but remember layout is super critical with these circuits,, it might look simple on paper but there are a lot of traps lurking when building multi stage preamps.
Phil.
Posted: 27 Sep 2015, 09:20
by alexhangman
Jubilee is not so trebly as #34 and other mods #36 and #39 has another tone compare to 2555.
Jubilee has a sweet tone but those mods have a little bit different.
Many people do these mods and it works -
for example
Posted: 27 Sep 2015, 12:14
by phatt
Thanks for the link,,
I did not hear any real difference in that clip but if that suits your needs then just mod the existing amplifier and a switch system or whatever suits your needs,, I was just giving you other possibilities you may wish to consider.
I've just been researching some pedals one of these might be cheaper and possibly more versatile;
Phil.
Posted: 27 Sep 2015, 12:52
by sinner
Can you take some gutshots of your JCM Slash 2555jubilee for me, please?
Posted: 27 Sep 2015, 13:18
by alexhangman
sinner wrote:Can you take some gutshots of your JCM Slash 2555jubilee for me, please?
What do you mean?
Posted: 27 Sep 2015, 13:53
by sinner
What do you mean?
Innards, PCB's pictures
Posted: 27 Sep 2015, 14:04
by alexhangman
sinner wrote:
What do you mean?
ok but it takes time. In the near future, when i will change tubes.
Posted: 12 Oct 2015, 16:06
by okgb
It's allot of reading on that Metro site, gets a little confusing with people trying different things
but sometimes not a strong consensus on the different ways to get that sound !
Posted: 13 Oct 2015, 19:39
by alexhangman
I just bought full amp Marshall JMP '79 with those mods #34/#36 from Dukeamps (Nigel). Amp on its way.
Posted: 23 Oct 2015, 20:56
by alexhangman
Preamp 2203/#34 on its way too.
Posted: 07 Nov 2015, 15:36
by alexhangman
my JCM800 preamp
Posted: 15 Nov 2015, 03:06
by okgb
Nice work ! What schematics did you use for this ? I was going to build one with a jubilee one channel and an AFD the other
