Selmer - Treble 'n Bass 50 Mark II  [schematic]
Has thanked: 4411 times
Been thanked: 2139 times
I bought this wreck of a Selmer TnB50 for hardly any money - but may still too much. I knew it wasn't working and humming loudly, I wasn't informed of the fact that it was humming without a speaker connected. The head cabinet and OT are non-original, rectifier socket is empty and has a solid state rectifier installed.
3A and 5A fuses where you want to see .5A and 1.5A. I put in the correct values, removed the tubes and fired up the amp again, HT .5A fuse blew again.
Three prong plug cut off, two prong put on. I read this as: a tech declared this amp a loss for PT issues and cut of the plug to avoid anybody plugging it in. It then ended up in the hands of somebody who didn't know to read these signs and put on a 2 prong, leaving the ground unconnected - other side is soldered to the chassis inside the amp. I re-installed a 3 prong plug and this really did the amp some good.
Trying the amp again without new HT fuse gave me some voltage in the 350V range on the power rail, but no filament voltage on the tubes. The 5V heater winding for the rectifier seems to be ok, delivering 5.9V when nothing is connected.
The problem is in the rectification as I see things now. The amp now has a full wave bridge rectifier installed....
However, the negative DC leg of the SS rectifier is in this amp, not grounded. Should I convert to a full diode rectifier?
The power transformer has a CT that connects through the .5A HT fuse to the CT of the 6.3V winding and further to ground. Is the lacking of ground on the power/filament CTs what's causing the lack of filament voltage? I feel I should first make sure I have filment voltage before anything else...
powersection selmer.jpeg (21.57 KiB) Viewed 4074 times
There are a few different options I'm considering:
Risking another fuse at this point
Removing the SS rectification and put everything back to stock.
Selmer Treble 'n Bass Mark II schematic
deltafred
Has thanked: 814 times
Been thanked: 306 times
Post by deltafred »
Unless you also removed the SS rectifiers then the HT will still be present so any faults on that can cause the HT fuse to blow. (Leaky/shorted smoothing cap being the prime suspect.)
If it were mine I would -
Because the transformer has a CT you cannot use a 4 diode full wave bridge (as in top right) unless you use half the transformer (otherwise you would get twice the voltage) and remove CT ground connection because the -ve bridge connection is grounded. This is not a particularly good idea because half of the transformer secondary winding in now supplying all the HT current rather than it being divided equally between the 2 halves.
I never did like tube rectifiers and there are far better ways of achieving the same result. If you want tube rectifier sag then you can put an appropriate value resistor in series to give you some volts drop under load.
2. Connect the HT centre tap to the ground and put the HT fuse in the HT supply between the rectifier junction and the 32u capacitor / choke junction.
Putting fuses in ground lines is rarely a good idea.
- as always IMO and YMMV.
uncleboko
Has thanked: 58 times
Been thanked: 41 times
Post by uncleboko »
I used to have a Selmer Selectortone - the version with a fairly useless 15" speaker in mid 60s. I put it through a pair of Jensen Blues which gave an immediate boost in volume. Then a friend came up with the idea of boosting my guitar level through a mic preamp.....................................wow, serious overdrive!!
Thanks so much for the advice. The only reason for reverting back to the tube rectifier, would be to restore some originality to an already butchered up amp. I forgot the pics:
Something's happened to the amp - the board in broken in half:
I used 2 1N4007 diodes for the rectification, put HV fuse immediately after that, then on to choke and first filter capacitor. The 32uF were looking really swollen. Put the HV center tap to ground... but could not locate the filament CT. However, measuring the filament wiring I have continuity to ground...
Then there is the brown mystery wire, coming off the primary of the PT, but having no continuity with any of the other primary wires making up the voltage selector. This brown lead was soldered to the first filter cap :scratch: It is not the center tap for any of the secondaries. One of the primary leads of the PT is brown and soldered to the voltage selector - two brown wires on the same side of the PT?
Could put in a new fuse and try it...
deltafred
Post by deltafred »
The brown mystery wire could be an electrostatic screen (usually a thin sheet of copper insulated on one side so as not to create a shorted turn) between the primary and secondary windings to prevent mains borne interference being capacitively coupled to the secondary (if I remember correctly). It is usual to connect it to ground.
I did fire it up and was happily suprised it didn't blow the fuse again. Measured about 500VDC as B+, there was filament voltage, so plugged in some tubes, and the beast was alive! It sounds big and bright, as expected. I like the bass channel for guitar, especially for single coils. Anyway, meanwhile, the bias was still at -55VDC; I replaced the electrolytic in the negative bias circuit and also updated the resistor that according the schematic was supposed to be 180k, but measured as 120k. Then the bias was -33VDC. Plate voltage in the preamp and PI: V1=180-90VDC; V2=120-30VDC; V3; 203VDC. Power tube plates: 440VDC
Still testing with the old, sacrificial tubes,
I connected the electrostatic screen mystery wire to ground, but couldn't really compare the noise level, too late for the neighbors... More measurements tomorrow.
deltafred
Post by deltafred »
Good to hear that it's going again.
The very first amp that I repaired was a Selmer PA100 in about 1967. Someone in my school band picked it up for peanuts because it was faulty, I fitted a replacement OT and we used it until we finished school and went our separate ways.
I had never heard of or encounter an electrostatic screen before, it's also not indicated on the schematic. Found this great site with more info: https://www.sciencedirect.com/topics/en ... tic-screen
I connected it to ground, but this did not improve noise or hum in my opinion. However, surfing the Selmer fakebook group, I came across a similar chassis to mine. There were a few changes within the TnB Mark II - the transformer without bell cover is used from late '66 onwards. For this layout, the filter caps are mounted next to the PT.
My unit is 44971, and the mustard caps are D6N - 4th Q of 1966
It's serial 42393, and the mustard caps are B6N - 2nd Q of 1966
Screen Shot 2021-08-02 at 14.40.20.png (215.9 KiB) Viewed 3744 times
Looking at the power section, it does seem like the brown wire goes to the ground point near the filter cap:
TB 42393 power detail.jpeg (40.61 KiB) Viewed 3744 times
Went ahead and ordered a 20uf+20uF+20uF+40uF to replace the other can cap, don't understand why I didn't do that the first time. It's still humming quite a bit, trying to remember the words, it's been a long time. Don't know what you can expect from electrolytics after 56 years.
I'll share some sounds soon: it's loud, clean, chrystal clear highs, heavy round bass. And this is without giving the preamp section a good look.
Thanks so much Fred!
candletears7
Been thanked: 5 times
Post by candletears7 »
Sounds fantastic! Well done on persevering with this great old amp.
