Alembic F2B! (PCB and Layout)
edge11
Post by edge11 »
What transformer are you guys using for the pcb?
How much is the shipping for the tube town tranny to the usa?
Is there a cheaper alternative?
Thanks guys.
phatt
Been thanked: 343 times
Post by phatt »
You may wish to consider a switchmode supply?
If so,,,This might interest you.
https://www.freestompboxes.org/viewtopic ... 28&t=15954
Phil.
ToneKarma
Post by ToneKarma »
Hasn´t anyone checked this site for another PCB layout of the F2-B aka Fender Showman preamp ?
http://www.lorcan.me/projects/tube-bass-preamp/
This supplies the PSU and tube board as PCBs.
However I´d use a CF after the last tube stage and not just a pot as suggested on the website.
BTW, the "infamous mod" done by Pete Cornish to Dave Gilmour´s F2-B was likely nothing else as a change of the cathode bypass capacitor to something more useful for guitar and by adding a CF (the "extra tube", that is) to get an output level that can be fed into FX (which is basically what DG does ... he feeds the processed signal into the power amps of his Hiwatt amps later on but not directly after the preamp).
ezugaru
Has thanked: 37 times
Post by ezugaru »
Hey guys! I just found this thread, does anyone still have the files that Darkglass uploaded? the links are completely dead, thanks in advance.
BTW did someone else built it?
You are not dumb if you are a good person, is just that dumb people don't recognize the good things.
Fredenando
Has thanked: 453 times
Been thanked: 90 times
Post by Fredenando »
ezugaru
Post by ezugaru »
Hey thanks a lot!
phantombox
Post by phantombox »
Would there be another way to lower the outputs that doesn't involve a 2nd tube stage?
Maybe an L-pad or even a transformer to get a balanced output signal?
Phantombox
phantombox
I built one of these Alembic F2B's. I paralleled the input jack throu a DPDT switch and this works fine for 2 separate outputs. But for some reason, the output jack for both channels (the one that is connected after a 47K resistor from channels A out and B out) doesn't work. Do they have to be 1% precision R's???
Phantombox
phantombox
On the output jack for both channels, only one comes out. I triple-checked the connections with a digital volt meter. If nothing plugged in only one channel is present. If there is a cable (mono 1/4 plug) connected both channels are present but only one comes out.
Phantombox
delaystomper
Post by delaystomper »
hi does anyone have the pcb and schematic for the alembic project build by drakglass i would love to build it but i find no documents
can you provide them to me please?
email
crashedsatellite@yahoo.com
snofla1900
Has thanked: 83 times
Been thanked: 7 times
Post by snofla1900 »
You might be looking for this infomation , more behind this link:
http://moosapotamus.net/ideas/alembic-f-2b-preamp/
