I've been working on a 8 output 9V psu for a friend recently. It is powered from a single 2x18V 40VA choke and using LM317T regulators. The schematic is inspired from Ken Stone's CGS66 bipolar psu with slight modifications (and I've swapped the negative rail of course).
It uses fixed resistors to achieve theoricaly 8,97V on each output, reducing costs and risks of failure from the trimmers which were in the original design.
As it should be quite reliable I will build another one for me soon... and I think it could be interesting to share the pcb artwork here too.
Use 1/2w 1% metal resistors and caps rated over 35V (50V or 63V prefered). Diodes are 1N4007UF.
( please don't mind about component numbers in the layout: it is 8 times the same "module").
edit: here is a 3D view ( NOTE: the 2 big caps are not correctly oriented in this view, use the layout as reference).
