Analog tap tempo for PT2399
- earthtonesaudio
- Transistor Tuner
Breadboarded and seems to work:
SIM
Press and hold the switch to reset, ramp up, and finally hold the control voltage. Higher CV=longer delay. Some of the values are altered to make it look better in the sim. More appropriate values shown in the image below. I have them this way in the sim because it's dreadfully slow to watch the circuit operation at normal speeds.
There are plenty of other ways of doing this, sure... but there's something satisfying about using the PT2399 itself to implement the tap-tempo control.
The unlabeled IC is a 555 wired as a Schmitt trigger.
SIM
- rocklander
- Has thanked: 1406 times
- Been thanked: 231 times
- Contact:
I don't understand how to implement it, but I LOVE the idea
- earthtonesaudio
- Transistor Tuner
I had a nice reply outlining how it works and then Firefox froze up on me.
I'll break it down into the main blocks:
The footswitch is connected to an RC network that slows down the high-low transition and the 555 goes high when the input goes below 1/3 of the supply. The 555 also has hysteresis so altogether this is a debounce circuit. Nothing too fancy here.
The output of the 555 goes high and turns on S4, which turns on S1. S2 and S3 briefly see a logic high due to the rising edge that is let through by the 100n cap, but then they see a logic low again when the charge is bled to ground by the 1k resistor. So S2 and S3 close briefly at the beginning of the process.
S1 stays on as long as the 555 output stays high, so you keep holding the button down and current flows through the 100k into the op-amp. The 100n cap across the op-amp makes it an integrator, so the current flowing in causes the output voltage to ramp up slowly.
After a while you release the footswitch. This transition is debounced and the 555 output goes low. S4 opens, S2 and S3 remain off (no change) and the control input for S1 goes low due to the 12k and pot resistance to ground.
This open-circuit at the input of the op-amp means no current flows and the output voltage is held at the current value.
If you were to press the button again the op-amp output would again go low and slowly ramp up, release the button again and it will hold at a new value.
Now we can look at the discrete buffer. The 0-5V output of the integrator is divided in half by the 10k:10k resistors and the resultant 0-2.5V is buffered by the BJT op-amp. The output is connected to pin 6 of the PT2399. The PT2399 will respond to a control voltage between 0-2.5V by varying its delay time from minimum to maximum, respectively.
So finally the behavior of the circuit as a whole is this:
Press and hold footswitch for X milliseconds, then release. This causes the PT2399 delay time to first reset to min, then ramp up to Y milliseconds and finally remain at Y milliseconds after the footswitch is released.
The slope trim potentiometer allows you to adjust the ramp speed such that X=Y. Under this condition the footswitch is a delay time input. Hold the switch closed for 300ms, get a 300ms delay.
[edit]
Here is an updated circuit which includes the power-on reset to prevent latch-up, and the integrating resistor value is changed to 1M. The range of adjustment is between 300ms and 2000ms full-scale. That means it will take somewhere between .3 and 2.0 seconds to get the PT to produce its maximum delay time. This ought to cover any variation between different PT chips.
[edit]
- juanro
Regards,
Juanro
Are you sure about that? I was under the impression that pin 6 was a current sensing (or sending) pin... the R to ground (digital ground) controlled how much current flowed out of it, but voltage of pin 6 remained more or less 2.5v all the time.earthtonesaudio wrote:The PT2399 will respond to a control voltage between 0-2.5V by varying its delay time from minimum to maximum, respectively.
Regards,
Juanro
La única verdad es la realidad.
- earthtonesaudio
- Transistor Tuner
I used PRR's model of the inside of a PT2399 (link) and real-life testing on my own breadboard confirms it. Driving pin 6 with a voltage source between 0 and 2.5V does indeed vary the delay time from min to max.
The difficulty of achieving this is that few standard op-amps will pull the required current down to zero volts. You could use a bipolar supply but PRR's discrete buffer does the job with a single supply.
- juanro
Hey, haven't seen that! It's the cookie!earthtonesaudio wrote:I used PRR's model of the inside of a PT2399 (link) and real-life testing on my own breadboard confirms it. Driving pin 6 with a voltage source between 0 and 2.5V does indeed vary the delay time from min to max.
Juanro
- rocklander
- Contact:
probably your screen resolution. right click on the image and copy it, then paste it into an image program (like photofiltre)Mbas974 wrote:Is there any reason why I can't see the full schematic image ?
- rocklander
- Contact:
not I sorry...
- earthtonesaudio
- Transistor Tuner
I built it. It basically works, meaning holding the switch resets then ramps up the delay time, but it is neither user-friendly nor optimized to work *well*.Mbas974 wrote:tx again..
Anyone in this forum , did build it ?
