a tube box on 9V
- rocklander
- Has thanked: 1406 times
- Been thanked: 231 times
- Contact:
what is it, and what does it do?
got schematic?
got schematic?
- Dirk_Hendrik
- DarkRain
Just a quick question: You are using 9v to supply tube heaters? It's a little bit under the specified voltage (12.6 between pin 4 and 5) - you could use 12v to supply the whole pedal and get more headroom and also you will be within the specs for the heaters.
Best regards,
Gabriel Tudoran
Best regards,
Gabriel Tudoran
- DrNomis
- Has thanked: 98 times
- Been thanked: 279 times
Looks like the schematic is based on the Valvecaster.......
- Dirk_Hendrik
Below what we call a building drawing.
The Schematic looks like this:
Note the differences. The building diagram is handy for building the thing, even if you do not know what it does. The schematic is to understand what is going on.
(Thanks Simon, Valvecaster confirmed)
- DarkRain
Ok ... but again... wouldn't be more convenient to use a 12V supply then a 9V? ?
Best regards,
Gabriel Tudoran
Best regards,
Gabriel Tudoran
- Dirk_Hendrik
- DrNomis
I agree Darkrain, 9V would mean that the cathodes of the valve aren't able to reach their full electron-emission capabilities, also, I seem to remember reading somewhere that if you run a valve at a lower heater voltage, it can lead to something called "Cathode Poisoning", incidentaly, I tried building a Valvecaster but it didn't work well and hummed alot.....
- copachino
DrNomis wrote:I agree Darkrain, 9V would mean that the cathodes of the valve aren't able to reach their full electron-emission capabilities, also, I seem to remember reading somewhere that if you run a valve at a lower heater voltage, it can lead to something called "Cathode Poisoning", incidentaly, I tried building a Valvecaster but it didn't work well and hummed alot.....
what about 18VDC??
- DarkRain
Well ... again why?! Standard voltage for heaters is: 6.3 or 12.6 so i choose 12.6 beacause:copachino wrote:DrNomis wrote:I agree Darkrain, 9V would mean that the cathodes of the valve aren't able to reach their full electron-emission capabilities, also, I seem to remember reading somewhere that if you run a valve at a lower heater voltage, it can lead to something called "Cathode Poisoning", incidentaly, I tried building a Valvecaster but it didn't work well and hummed alot.....
what about 18VDC??
1 i can supply the heaters with the same PSU
2 it's better the 6.3 in terms of voltage
Why to drop 3 volts or 5v on a resistor ... (@300 or 150mA it can get hot) when... you don't have to drop anything and use 12V as supply ...
Best regards,
Gabriel Tudoran
- DrNomis
what about 18VDC??
18V DC will burn-out the valve heater, unless you put a resistor in that'll drop about 6V (which means alot of power dissipation in the form of heat), once the heater burns-out the valve is useless......
- rocklander
- Contact:
how much current would it be drawing? would an lm7812 be the ticket?DrNomis wrote:copachino wrote:DrNomis wrote:I agree Darkrain, 9V would mean that the cathodes of the valve aren't able to reach their full electron-emission capabilities, also, I seem to remember reading somewhere that if you run a valve at a lower heater voltage, it can lead to something called "Cathode Poisoning", incidentaly, I tried building a Valvecaster but it didn't work well and hummed alot.....
what about 18VDC??
- DarkRain
According to the DS it's 150mA per tube @ 12.6v that would be 18-12=6v dropout @ 150mA that would be 1W of power, a 7812 in a To220 package would be ok.rocklander wrote:how much current would it be drawing? would an lm7812 be the ticket?DrNomis wrote:copachino wrote:DrNomis wrote:I agree Darkrain, 9V would mean that the cathodes of the valve aren't able to reach their full electron-emission capabilities, also, I seem to remember reading somewhere that if you run a valve at a lower heater voltage, it can lead to something called "Cathode Poisoning", incidentaly, I tried building a Valvecaster but it didn't work well and hummed alot.....
what about 18VDC??
Best regards,
Gabriel Tudoran
- Dirk_Hendrik
- atreidesheir
It would be a beautiful pedal to look at.Dirk_Hendrik wrote:Looking forward to the 4 tube version!
