Square to triangle wave conversion
I have been mulling over the idea of a fuzz pedal that would create(convert) other waveforms besides a square wave, most notably triangle and sawtooth. Has anyone done an experiment such as this before? I was thinking maybe an integrator circuit using a single op amp to get the triangle conversion. I have seen a few circuits for sawtooth conversion but, not many(really none) in regards to the triangle waveform. Any thoughts/ideas would be much appreciated.
By the way, I am new here so hello to all!
- phatt
Urr? Maybe you are confusing the the square wave of a distorted audio signal which contains many frequencies with the triangle/square waveform of a fixed freq LF oscillator which is used as a control voltage for things like Vibrato. There is a big difference.
Phil.
Phil.
- Nocentelli
- Has thanked: 1152 times
- Been thanked: 954 times
- DrNomis
- Has thanked: 98 times
- Been thanked: 278 times
You could try checking out some of the circuits on this website:
http://www.musicfromouterspace.com/
Thanks! I have come to the realization that a triangle wave is not going to be the cheap,easy fix I was looking for. I am quite familiar with SSWSMS circuit and a good deal of inspiration came from it. It seems the likely solution is to stick with a more simplistic circuit such as the SSWSMS.
- commathe
You could use an integrator (an active low-pass filter without DC feedback). Though higher frequencies will create quieter outputs and lower frequencies might clip. Worth a try though!
Every octave up should be amplified by factor 2.commathe wrote:You could use an integrator (an active low-pass filter without DC feedback). Though higher frequencies will
(80Hz =1 160Hz =2 320 = 4 640 = 8 1,3kHz = 16)
electrip
