EMG PA-2 schematics,layout,etc
rcustoms
Has thanked: 361 times
Been thanked: 504 times
Post by rcustoms »
HI guys a xmas gift for all fsb forum
emg pa-2
EMG PA2 COMPLETE.pdf
(243.88 KiB) Downloaded 1129 times
not verified yet ,but i think that is ok
guitars,pedals and amps.
@zuleta.rafael(Instagram)
rcustoms
Post by rcustoms »
c2 and c6 are poliester ,the rest caps are tantalum
Has thanked: 1111 times
Been thanked: 955 times
You're lovely, thank you :)
Merry Xmas
andregarcia57
Been thanked: 76 times
Post by andregarcia57 »
Great!
Thanks you!!!
rssss, 49.9k and 499k rsssss
rcustoms
Post by rcustoms »
yes ,believe it or not ,see the picture
andregarcia57
rcustoms wrote:yes ,believe it or not ,see the picture
I believe yes.
gmulak
Post by gmulak »
I believe yes.
What is the R4 500k? Is that a pot or trimmer?I could not find it out!!
rcustoms
Post by rcustoms »
yep, its a trimmer control
ca_santos
Post by ca_santos »
Hi guys! The TL062P is too hard to find, is there any other IC to use as an alternative?
Thanks!!
Ps.: I'm from Brazil =(
mictester
Has thanked: 34 times
Been thanked: 771 times
Post by mictester »
ca_santos wrote:Hi guys! The TL062P is too hard to find, is there any other IC to use as an alternative?
Thanks!!
TL072 LF353
The TL062 is easily available from Tayda, Futurlec, Farnell, RS, etc, etc..... The '062 was chosen because it's designed for low current consumption.
EddieTavares
my favorite amplifier: marshall
Been thanked: 18 times
Post by EddieTavares »
Thanks!!
It's very ease to find that chip here in Brasil if you forget the sufix "P", eg.:
http://tiggercomp.com.br/novaloja/produ ... ts_id=6771
http://loja.multcomercial.com.br/circui ... onics.html
Quem amafagafar mais amafagafinhos melhor amafagafigador será!!!
ManCave666
Post by ManCave666 »
What is the transistor in the upper left corner of the pcb?
mimmotronics
Post by mimmotronics »
ManCave666 wrote: 22 Jan 2017, 15:42 What is the transistor in the upper left corner of the pcb?
Looks like they're using it as a diode.
rcustoms
Post by rcustoms »
yep
