Its a vol,tone and mid boost.
Jackson/Charvel JE1200 schematic [schematic]
- Ice-9
- Degoop Doctor
here is a trace i have made from my charvel model 4 actives in case its of interest to anyone.
i90.photobucket.com/albums/k243/lenny1dog/P7160001.jpg (dead link, see below)
- nickthemen
- Ice-9
- Degoop Doctor
nickthemen wrote:That one with a ? is 220k in the schematic i have.
Does your schematic check out the same as mine. (I RE'd mine from my own guitar, would be great if yours is the same which would verify mine)
- nickthemen
- rhandy gaye
The following pics/work are not mine so, I can take no credit and don't know of any mistakes. I downloaded them yonks ago and found them on a disc the other day.
I was going to build it but, never got around to it.
- jax_wir.gif (14.17 KiB) Viewed 11856 times
- jax_top.gif (10.71 KiB) Viewed 11856 times
- jax_bot.gif (8.87 KiB) Viewed 11856 times
- rhandy gaye
Don't know if it is verified but, the layout and traces are very very close to the original (looking at photos), ie this is almost exaclty a je-1200.
- rhandy gaye
pic from brochure
- je.tiff (146.23 KiB) Viewed 11834 times
- rhandy gaye
found this in google japan
- A3F4_ch_s5.jpg (68.22 KiB) Viewed 11788 times
Just what I've been looking for!!
I am currently building a Keeley Katana pre amp. Awesome pedal, which takes my amp (local Australian built modern plexi) to new heights. I am looking to incorporate a switchable mid boost following the preamp (I might even try to incorporate a pre/post switch, but first things first....).
Anyway, I have a few questions/proposals if someone can help:
- given this will be following a pedal pre amp, I am assuming I omit VR1
- what is the purpose of R2 @ 220k?
- I am going to replace VR2 with a fixed 50k resistor, as I don't need a volume control (level will be dictated by the Katana)
- I am going to omit VR3, as I simply want a fixed mid boost and don't need a mix control. I am assuming I simply take the output of R4 to the Pot of my Katana level control. Although I could wire this post the Katana Pot, which I guess would apply a mid boost to an attenuated signal vs attenuate a preamp/mid boost signal.
Any help on the above would be appreciated!
One for the breadboard tonight.......
Cheers
Cheers
- rhandy gaye
what you wanna do sounds cool, i'm gonna have a think about what you've written.
for now though, i wouldn't leave out any pots, but put trim pots in so you can muck around with some settings.
I've just finished breadboarding it - relatively high component count (for me anyway, say compared to the Katana), so a little time consuming!
Off to the studio tomorrow night to have a listen (and make sure it works/I've done it right)!
Will report back......
a mi me funciono perfecto se escucha muy bien.
- EddieTavares
I am not sure if it's correct, I found it in a russian forum.
- EddieTavares
It works closer to Demeter Fat Control.
Thanks. Finally I found that thread too. There ist a hand drawn schem going with the shown PCB further above in this thread all from that Russian forum.
Perhaps someone can verify this schem. OP Amp = LF442CN
- Ice-9
- Degoop Doctor
Yeah, I traced that hand drawn schematic from my own model 4 charvel the LF442CN is correct, it is a low power IC which helps with the battery power consumption.95H wrote:Hi,
