Great!, thanks, I'll give it a try.culturejam wrote:We left out all of the parts related to the relay switching and the other "features". This is just the part of the circuit that makes noise.Sweetalk wrote:The schematic is incomplete?, there are some transistors in the PCB that I don't saw in the schematic.
But the photos are there so that anyone who wants to draw up the switching and low-battery detection and whatever that slide switch does, go right ahead. They would likely make cool stand-alone project for people to add to their existing pedals.
Suhr - Riot [traced]
- Sweetalk
- mxrmxr
- Degoop Doctor
I'll measure C12 and let you knowculturejam wrote:You did a little bit cleaner job than I did.
Nice work!
I accidentally destroyed C12 when I removed the goop (it got ripped off). Can you measure it in-circuit so we'll have a ballpark idea of its value?
No. It's more like Guv'nor with a single tone control, three diode clipping options, a single tone control, an op amp buffer, vref biased via op amp, and electronic switching.Steven_M wrote:Is this a tube screamer with an op amp buffer and electronic switching?
I'd love to see someone else trace from these photos and see if you come up with what I did.
- mxrmxr
- Degoop Doctor
Many thanks. Degoop Doctor rank is that goodmodman wrote:Great! For showing true freestompboxes hackers spirit you are rewarded the Degoop Doctor rank. Culturejam already did it, but this is excellent for verification and spotting version changes...mxrmxr wrote:I had a spare few minutes so I went for a degoop
Sorry I didn't know Culturejam had already done it. I didn't see any pics around
- mxrmxr
- Degoop Doctor
Yeah no prob will doIvIark wrote:It looks like a 1210 package to me, assuming the resistor next to it is an 0805. mxrmxr - could you measure and see if C12 measures close to 3.2mm x 2.5mm please?culturejam wrote:Mark, can you figure out from the photo what the SMD package size/code is for C12?
- Dirk_Hendrik
Some forummites don't drop in too often.... but never fail to deliver Much apppreciated!mxrmxr wrote:I had a spare few minutes so I went for a degoop
- culturejam
They weren't in a public area of the forum, so there's no way you could've seen them unless you're a member of the Tracer's Fund.mxrmxr wrote:Sorry I didn't know Culturejam had already done it. I didn't see any pics around
You did good!
Yes.bobo wrote:C12 on pcb = C5 on madbean schematic.?
By the way, if you are going to have a go at building the Uproar, here are the parts values I settled with in my build:
(the clipping diodes I just threw in their for fun...they are not very close to the original)
Code: Select all
R1 1k
R2 470k
R3 1k
R4 10k
R5 1M
R6 470R
R7 12k
R8 8k2
R9 100k
R10 100R
R11 20k
R12 20k
C1 22n
C2 47pF
C3 100pF
C4 220n
C5 100n
C6 470pF
C7 2u2
C8 10n
C9 2n2
C10 33n (was measured as 22n)
C11 10uF
C12 47uF
C13 47uF
D1 LED (green, diffused, 3mm)
D2 1N914
D3- D5 1N60 schottky
D6 1n4001
- culturejam
I won't have time to redraw my schematic (factory part numbers) before I go on vacation this weekend, so here's a rundown of the clipping diode switch configuration:
The switch selects between three clipping (to ground) options:
1- A pair of Red LEDs in parallel
2- A pair of series 1N34a diodes in parallel with another pair of series 1N34a diodes (orientated opposite of the first pair)
3- A pair of series silicon* diodes in parallel with a blue LED
NOTES:
• Option 2 has a 470R resistor in series with the diodes (presumably to prevent the diodes from discharging the last stage's output cap)
• Option 3 has a 220R resistor in series with the diodes
• For Option 3, I cannot 100% verify that the diodes are silicon, because I can't find the part number anywhere. They are marked "S17" only.
NOTES:
- IvIark
- quaternotetriplet
bookmarked.
- ppluis0
Hi Culturejam,culturejam wrote:3- A pair of series silicon* diodes in parallel with a blue LED
NOTES:
Perhaps these SI diodes are schottky. Try to measure the voltage drop with a multimeter, that is typically less than in a normal silicon, since the main board are disconnected to the front one and there is no continuity through the switch.
Regards,
José
- culturejam
Yep.Sweetalk wrote:Finnally it's a modified Guv'nor!, without the tonestack, clipping diodes selection and some value changes for what I looked at first sight
I said this in the third or fourth post in this thread:
It's more like Guv'nor with a single tone control, three diode clipping options, an op amp buffer, vref biased via op amp, and electronic switching.
- Sweetalk
Ups!, I missed that!, sorry .culturejam wrote:Yep.Sweetalk wrote:Finnally it's a modified Guv'nor!, without the tonestack, clipping diodes selection and some value changes for what I looked at first sight
I said this in the third or fourth post in this thread:It's more like Guv'nor with a single tone control, three diode clipping options, an op amp buffer, vref biased via op amp, and electronic switching.
Riot is done, Shiba it's your turn!!!
- culturejam
It's good that you did, actually. Having a second person* come to the same conclusion means we are likely accurate in our trace.Sweetalk wrote:Ups!, I missed that!, sorry .
*Actually, you are the third person to point this out, as BajaMan was the first to mention it in the Tracer's Fund when I posted the initial draft schematic.
- Sweetalk
If I have time i'll do a comparison of the guvnor and the riot, will be a nice one to do the riot in the well known and verified guv'nor's pcb's that are around.culturejam wrote:It's good that you did, actually. Having a second person* come to the same conclusion means we are likely accurate in our trace.Sweetalk wrote:Ups!, I missed that!, sorry .
PS: holy sh** my english it's becoming crappier every day!
- Sweetalk
Well, I've made a comparison for the Riot and the Guv'nor. There are a few essential differences like the output buffer and the opamp based Vref on the Riot, the full tonestack on the Guv'nor vs Single tone control on the Riot (very easy to implement in the Guv'nor). Besides that you can easily make a Riot from the Guv'nor in the Tonepad Layout with a few changes. I hope it helps!:
- IvIark
Well he obviously saw the business Analogman got out of the Bluesbreaker and thought he'd have a bit of that too
- Greg
Wampler's been building a modified form of the Guv'nor for years as his Plextortions hasn't he ?IvIark wrote:Well he obviously saw the business Analogman got out of the Bluesbreaker and thought he'd have a bit of that too
