Lovepedal - Eternity  [traced]
invictus
Post by invictus »
speaking of lovepedal, does anyone have a schematic of the eternity model? i like the sound of it from the clips i heard so far. any special thing going on in the circuit? or is it another TS mod?
Has thanked: 3181 times
Been thanked: 659 times
(Hi invictus, it split this from the previous thread. It will get faster response this way. Don't hesitate to start a new thread! thanks.)
Did a quick search but didn't find anything. What kind of circuit is it?
invictus
Post by invictus »
thanks modman!
from the video demos and soundclips i heard, the eternity is quite a good booster/overdrive.
as to what's goin on with the circuit, i really cant find anything yet. maybe someone else here can throw some info.
Been thanked: 108 times
Herre are pictures from the:
Lovepedal Eternity (white)
Lovepedal Eternity (white) inside
The thick (or sick ?) white cables and the black goop are responsible for the unique mojo-sound.
invictus
Post by invictus »
analogguru wrote:Herre are pictures from the:
looks like those wires are left over from house wiring... could be used in wielding machine or industrial power tools. :D
my favorite amplifier: Stopped using amps mostly...
Has thanked: 64 times
Been thanked: 152 times
It's funny - it says on the jacket that it's only 22 gauge. Of course, it also says 600v 105degree, so it's probably thick because of the heavy jacket.
Hmph, that's the kind of wire you use inside tube amps. Does he think that's where the mojo comes from? Personally, I use the wire stripped out of CAT5 cable - it works great!
invictus
Post by invictus »
i tried searching for some info about the circuit of the lovepedal eternity but came out with nothing.
i guess just few people are interested.. :lol:
or maybe those people who were able to trace the schematic found out that its not worth discussing. :?
Pedalpusher
Post by Pedalpusher »
Sean uses a "mystery" chip. It sounded like a Cusack Screamer when I put a TL072 in it.
invictus
Post by invictus »
well that's an interesting info... now im starting to get really curious.
tuemmueh
Post by tuemmueh »
Try a Son of a Screamer with some symmetrical clippig and lower R2 to 3k3, R3 to 20k and C2 to 100n, R1 is 1M and C4 is 150n. R6 is 330R and C6 10uF.
That's it.
invictus
Post by invictus »
tuemmueh wrote:Try a Son of a Screamer with some symmetrical clippig and lower R2 to 3k3, R3 to 20k and C2 to 100n, R1 is 1M and C4 is 150n. R6 is 330R and C6 10uF.
That's it.
will do... if this is really the circuit, the only fun part will be finding what pedalpusher called the "mystery" chip. but based on the values that you mentioned, inserting a TL072 in it must not give so much of a bad output sound...
will check it later, a rather small circuit anyway... where did you get the info? you traced it yourself?
tuemmueh
Post by tuemmueh »
source of info is secret, sorry. Didn't trace it my self.
A TL072 won't sound that good in there, try a RC4558 or 1458, a 4558D is the original IC for the circuit. Another IC is offered by Lovetone as an "official alternative" ;), that one is an 4559D.
A TCL2262 is said to sound "fat" in there and there is a rumour ;) that NS LF535N should produce the best sound ... lots of possibilities, have fun!
btw ... I haven't built it myself. I'm faithful to my beloved RAT ;D
invictus
Post by invictus »
i built the circuit based on tuemmueh's info...
played through it for a while... being a TS circuit, the sound is largely influenced by the combination/type of clipping diodes..
i used 1n4148, 1N34, 1n60, 1n4002, different colors of LEDs, and lots of combinations of the aforementioned diodes. (both symmetrical and assymetrical config)...
for the IC, i used 4558DD, TL082, 4580D, and RC1458.
results? ahhhmmm.. yeah, the sound came very close to the sound clips and videos of the eternity... easily notable is the "GLASS" feel of the tone knob. can get really sharp when maxed. also, the clean boost is nice. lots of "headroom" as other people refer to it.
overall, it is a modded TS. that's it. love it or hate it... :lol: now lets wait for someone to verify the circuit info above... :wink:
.. i'll post the schematic based on tuemmueh's info later, with a note that its not verified.
tuemmueh
Post by tuemmueh »
Hi invictus.
Thanks for your review! I think I'll build one, too. Someday .... ;)
Which ICs did you use?
briggs
Has thanked: 19 times
Been thanked: 34 times
Post by briggs »
Does anyone know where I can get the NS LF535N? I can find the LF353 but no NS LF535N :(
I am Klon.
tuemmueh
Post by tuemmueh »
It's my fault .... the LF353 is correct.
briggs
Post by briggs »
ah, ok. Thanks.
I am Klon.
briggs
Post by briggs »
Here's the scheme, the IC type as tuemmueh says is LF353.
I am Klon.
invictus
Post by invictus »
here's another one just the fun of it....
https://s190.photobucket.com/albums/z271 ... chem-1.jpg
:) [/img]
tuemmueh
Post by tuemmueh »
oh, I forgot, take 4 diodes for clipping like in the schem above. 5k for tone and 500k for volume should also be the original values, but .... ;)
