Lovepedal - Eternity  [traced]
Hides-His-Eyes
Has thanked: 47 times
Been thanked: 63 times
Post by Hides-His-Eyes »
I remember you, you PMed me on harmony central once!
jwpartain1
Has thanked: 49 times
Been thanked: 59 times
Post by jwpartain1 »
Does anyone else have an opinion on handwiring a PCB version of a pedal? I'd really like to do it for kicks, but maybe I'd also get a little bit less treble loss in the circuit? Just asking.
Is that directed at me Hides? I'm not a harmony central user at this time, and nor have I ever been :)
Harold
Been thanked: 16 times
Post by Harold »
Harold wrote:
Harold wrote:Can anyone give me a pointer where to look for the squeel's origin?
I just discovered that R3 was 10k instead of 20k and R2 was 1k instead of 3k3. Replacing them reduced the squeel, but with all pots open it still goes berserk. :(
A very late follow-up: I separated the input from the output wire and the oscillation was gone! :applause:
Another lesson learnt the hard way ;)
DIY-Layout.com: Online stripboard layouts
whiskeytown
Post by whiskeytown »
Rich_S wrote:So I'm NOT the only one. I've built three E's now (a Wampler SD-1 mod, and two E6(?). All three are noisy: hiss, hum, and radio stations. The SD-1 mod picks up French Canadian bible-thumpers, the E6's pickup up some Asian language (maybe Korean from Toronto?) Instead of "Eternity" we should call it "U.N in a Box" or maybe "Small World After All".
dude you should avoid crapy MC1458 opamp and try just regular NE5532, TL072, RC4558 or BA4560.
Harold
Post by Harold »
whiskeytown wrote:dude you should avoid crapy MC1458 opamp and try just regular NE5532, TL072, RC4558 or BA4560.
Tried them all and the one I liked best: MC1458.
No noise/hiss/radio problems whatsoever.
whiskeytown
and its also depends what value for gain pot you put in. With 1 Mega ohm pot for gain, this is realy noisy overdrive.
ryanuk
Has thanked: 16 times
Been thanked: 27 times
Post by ryanuk »
I just finished an initial build for one of these. By that I mean I built the PCB but its not boxed.
Initially I was using the stock values from the schems in this thread, save for the 150n which I didnt have and couldnt source easily. I found it too shrill at most of the "glass" settings. So, I read up on RG's technology of the TS article and set about making some changes. Here's what I ended up with...
Input cap - 220n
Drive - 250K
Drive filter network - 22K/1.5K/220n
Post-clipping LPF - 680/220n
Tone control filter - 220n/390
The aim was to give the pedal a little more gain without affect the frequencies which attract the clipping. This seems to have worked. There's deffo more gain now. Also I wanted to darken the pedal, hence the revised values for the filter and tone network. Now its more to my taste, perhaps a little too dark, I havent made up my mind yet.
I used the drunken dragon PCB. Its a little noisy - not osciallating but hissy. Hopefully once its boxed and shielded this will die down.
The circuit is very picky about ICs! I hated the 4558,TL072,LM353,NE5542,1458. I settled on a LM442. Immediately had a nice beffy response to it with surprising sustain. Im not usually a snob about ICs but that one really jumped out. Clearly different to the others.
Anyhoo, thats my 2c.
RyUK
lukatosh
Has thanked: 32 times
Been thanked: 180 times
Post by lukatosh »
Anyone have info about the eternity E6??
Happy new year!
Seiche
Has thanked: 202 times
Been thanked: 176 times
Post by Seiche »
lukatosh wrote:Anyone have info about the eternity E6??
Happy new year!
it has a white enclosure? :blackeye
lukatosh
Post by lukatosh »
yes!!... I saw a video on youtube and it sounded very good!!
Anyone have a schematic or info about the component variation in the E6 version?
lukatosh
Post by lukatosh »
anyone have info about the E6? thanks!!
lukatosh
Post by lukatosh »
Up!
culturejam
Has thanked: 391 times
Been thanked: 425 times
Post by culturejam »
It can't be that much different from the eleventeen other version of the pedal. [smilie=a_whyme.gif]
Seiche
Post by Seiche »
Up!
why don't you buy the current coupon deal and share a few gutshots? most of the time you can sell them for the same price or more after the deal ended.
lukatosh
Post by lukatosh »
:slap: Thanks for your help...
i live in chile... lovepedal pedals... don't even exist here as a brand...
the shipment is to expensive... that's why am asking here for info :) ...
anyone? can help with gutshots? :)
Seiche
Post by Seiche »
my guess is as this one has "more gain" (whatever that means, more volume or more distortion? pretty different idea) it uses either LEDs (more volume/headroom) or germanium diodes/only 1 silicon diode each way (more distortion). reviews should give more clue as to what the differences to the "regular" eternity are (or at least the one the schematic is based on).
"slight shift in the tone frequencies" could either mean the pot has a different value or the low-pass filter has a different cap, methinks.
IvIark
Has thanked: 507 times
Been thanked: 540 times
Post by IvIark »
A couple more vero layouts for the Eternity and Burst variety.
IvIark
Post by IvIark »
And after the recent discussions on here regarding SIP8 packages, I thought I'd do a SIP8 layout to see what space I could save. Three fewer columns and one extra row, but I think more space would be saved for the people not bothered about using standy up resistors.
Has thanked: 890 times
Been thanked: 703 times
Nice one :) Do you had any luck with single opamps? I've spend one hour going through datasheets without success
IvIark
Post by IvIark »
I've got a few single opamp datasheets. What are you looking for mate?
