Way Huge - Tone Leper [traced]
- analogguru
First:
Thanks Jeorge for everything and here some additional guts:
http://i3.ebayimg.com/03/i/000/cf/2d/c651_3.JPG
http://i12.ebayimg.com/03/i/000/cf/2d/c6d4_3.JPG
http://i19.ebayimg.com/02/i/000/cf/2d/c753_3.JPG
if you have $600,-- to in-waste, you can buy it here:
https://cgi.ebay.com/Ultra-Rare-Green-W ... dZViewItem
- devastator
any news ? schematic ?
Someone has the QOSTA's pedal pics posted by Mr.huge ?
- Way Huge - Tone Leper guts
- WAY HUGE TONE LEPER GUTS.JPG (18.51 KiB) Viewed 3008 times
- soulsonic
It's the Craig Anderton Frequency Booster. That's the schematic.devastator wrote:any news ? schematic
- puppiesonacid
soulsonic wrote:It's the Craig Anderton Frequency Booster. That's the schematic.devastator wrote:any news ? schematic
haahhaahahaha. thats for making that as transparent as possible hahahahah
here's another
- FreqBooster.pdf
- (236.9 KiB) Downloaded 441 times
- ggg_ca_frequency_booster.pdf
- (183.63 KiB) Downloaded 365 times
- devastator
ok I thought it was something else an unique Wha huge schematic.
So all boutique pedals are copied on Anderton design or something ?
- MoreCowbell
- abfackeln
- Degoop Doctor
I know the Way Huge Tone Leper is same circuit as the Craig Anderton Frequency Booster, but do we know what the stock value of the tone shaping caps in the Tone Leper?
(Formerly fjp1975)
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
lapsteelman wrote:I know the Way Huge Tone Leper is same circuit as the Craig Anderton Frequency Booster, but do we know what the stock value of the tone shaping caps in the Tone Leper?
Even the original project had the caps as an option... so the only reason to be absolutely sure of what WH used, is to look at the guts of a unit.This is a rare one from the early 90s from Way Huge and is based on the Craig Anderton Frequency Booster. Stock it gives a mid range boost (800Hz), but that frequency can be altered by swapping the 2, 22nF caps:
220nF - 90Hz (lows)
100nF - 200Hz (low mids)
10nF - 2kHz (mids)
4.7nF - 4kHz (upper mids)
But there seems no mystery here
