Lovepedal - Superlead [traced]
- culturejam
Got this in the post today. I like the red PCB.
I've got a layout in the works (it's done but I'm trying to optimize). Truth be told, I think I'm going to do my "own" version without the clipping diode switch (Lovepedal calls it a "Mids" switch).
Mumble, mumble, blah, something....Guv'nor with a single tone control...blah, blah, mumble something.
Note: I drew the switch as a SPDT. It's actually a DPDT with two of the sets of lugs connected together. It's more efficient as I have it draw, and I suspect Lovepedal uses a DPDT because it has more "anchoring". The switch itself is not secured to the enclosure, so the extra lugs help out to keep it from breaking.
Pretty damn sure it is correct as drawn. But as always, input is welcome.
- batteryacidtea
That's nice, and fast as hell! Thank you very much, sir!
- rocklander
- Has thanked: 1406 times
- Been thanked: 231 times
- Contact:
hadn't seen one before, so google imaged it... what's with the switch not being housing mounted? just waiting for dust and crap to fall in there
- Hides-His-Eyes
It's because board mounting the jacks like that requires you to use long-leg alphas, but the toggle switches match up with short leg alphas for pot length
Of course, wiser men than he mount the 3PDT offboard and put the jacks on the UNDERSIDE (e.g. EHX BB size pedals)
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
OMG, it's not Timmy
- Hides-His-Eyes
Nowt wrong with the design now, let's be fair.
- IvIark
Here's an unverified vero layout if someone wants to give it a go:
Watch the hidden track cuts which you'll see on the bare board layout. Everything is as per the schematic except I used a 100uF instead of 47uF for the main filter cap, and I didn't bother with the 100nF in parallel with it.
- sinner
Dammit Mark! I was in middle of doing that Great layout Sir
- IvIark
I was feeling particularly motivated for some reason ...
- culturejam
I could tell from the sound clips that it wasn't an Electra/COT. Way too much sustain. I actually suspected it might be FET-based.azrael wrote:And here I was expecting another COT derivative, haha.
I agree. I'm not crazy about how the switch is mounted, and people always bitch about board-mounted but unsecured 9v jacks, but otherwise it's quite sturdy and well built. And it sounds pretty damn good as well. And why shouldn't it? It's a tried-and-true circuit design.Hides-His-Eyes wrote:Nowt wrong with the design now, let's be fair.
I actually rather like Sean's thinking on this one. I'm usually the kind of guy who looks at a complex circuit and tries to figure out how to make it more simple (ie - reduce the number of pots/switches/etc). So a Guv'nor dirt section (almost exactly part-for-part) with a single, simple tone control is right up my alley.
That said, I'm going to build my own version and sell this one. I'd rather have $100 than this particular pedal.
It doesn't sound that way with my gear. It's fairly well balanced in the bass/treble department. My biggest gripe is that the Gain control taper is shitty. 3/4 of it is low gain, and then you get into JCM800 zone all of a sudden. I think maybe B100K would be a better choice?madbean wrote:Looks good. It also looks a little bass heavy!
Anyway, here's the messy layout I did. The next one I do will be for my slightly trimmer version, with a few value tweaks. That is, I'm gonna pull a Lovepedal on Lovepedal.
- SuperLead_v3_Layout2.png (16.29 KiB) Viewed 12033 times
- sinner
over 250 views and only 8 people pressed thank button? Awesome guys...
JUST PRESS THE FUCKING THANK BUTTON BIATCH!
- culturejam
I forgot to mention that the Superlead is available EXCLUSIVELY at Guitar Center:
http://www.guitarcenter.com/Lovepedal-S ... 1562916.gc
Sean has come a long way from those old gooped Electras, hasn't he?
- himister
sinner wrote:over 250 views and only 8 people pressed thank button? Awesome guys...
Ok Pawel! I pressed 3 times...enough???
Culture and Moska...awesome job fellas! I wanted to redraw it though, then I saw Moskas pdf.
Thanks...much!
- joeboo88
Hey simmer down, i just got here and thanked them just now, Sinner you are the man! i gave you a thanks to cuz you scared the crap out of me! Ha haby sinner » Yesterday, 08:28
"Ebay is a fucker" Sinner.
Ebay is a fucker ~ Sinner - If this is something unique, then I'm a teletubbie ~also Sinner
- Seiche
I just looked it up on the lovepedal site.
doesn't really sound all that special (the clip there), I let it play when reading through this. Sounds kinda artificial. Of course it probably sounds way better in person than through my crappy laptop mono
anyway. That Guitar Center only thing is kinda weird, especially when reading the description:
that switch, well guys, it's only 130 bucks, okay? don't expect too much! (like simple offboard wiring of 1 little spdt)
If this were the ultimate drive, why not go global?Guitarists rejoice, your quest for the ultimate drive ends here.
