Retro Channel Trouble Booster..
- Greg
OK guys, took a look inside & removed goop, but haven't traced it yet.
It's seems it's another transistor array setup similar to the Fuzz (sorry "proprietary chip" ).
If anyone is so inclined.. please make a start as I'm not sure when I can get it done.
I'll check pots, and anything else as needed.
Reason: put copyright notice and re-uploaded pictures
That board could be tiny if it weren't for the onboard switch. Really has gone to a lot of trouble to conceal that chip [edit: "proprietary chipset"]. Belt sander AND goop. I wonder if Bill Finnegan gave him his goop supplier when Lanceypants was schooling Bill on how to write a bogus DMCA claim? I've never had much interest in a treble booster but the SMD does look good.
- kleuck
To this point, i must say that i'm the first -after the Derangemaster which was a RM clone- to use this name "Trouble Booster", actually "Ballast Trouble Booster" in my case, non-sense joke about RM obviously.
I'm in contact with Lance regarding a change in the name of his booster, as i began selling mine almost 3 years ago now, and a Google search (asked a Canadian customer to do an English search from Canada to be sure) with "trouble booster" gives you mostly my pedal, not his one.
I was wondering if he cloned my circuit (a true new design), as i sent one or two to US, but according to your informations, no, it can't be done with a transistor array.
Randall Aïken said :
Q: Is there any advantage to using solder with a 2% silver content?
A: Yes. Silver solder keeps werewolves away from your amp.
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
I moved away some messages about DMCA policy which are interesting and deserve a place on the forum. Please restrict yourself to technical discussion and contributions in this section of the forum.
thanks
thanks
Thanks for the pics. I'm close to have a basic schem drawn, but I miss some connections for pin 8, 9 and 11 of the IC.
Pin 11 and 8 are supposed to be biased in some way, and pin 9 has to reach something. These connections are likely under the IC, so could you try with a continuity tester?
Also, from what I see from your pics, I have some with pins 12, 13 and 14 : which one are tied together and which ones are connected to ground? What I see doesn't match the expected set up from the other Retro pedal...
- Greg
Yes, the whole point of SMD is to reduce the size of things.. and yet here we have a simple circuit in a large box for no reason.AllegedRetroFreek wrote:That board could be tiny if it weren't for the onboard switch.
As well, the knobs completely cover the labels when at 12.00.. not very well thought out, given all that real estate for graphics.
You'd think LK being a professional guitarist would do these things a bit better.
Apart from that it's a pretty tidy build.
- tn_P1010499.JPG (29.73 KiB) Viewed 3525 times
- toneman
- my favorite amplifier: anything that works
- Completed builds: meatolation, wobolation, ringolation clones, PAiA synths/modulars, dipthonizer clone, MOTM modules, pedal mods and repairs
- Has thanked: 183 times
- Been thanked: 45 times
14pin IC.
Could be a transistor array(CA3046).
Or a quad opamp (TL064,74,84).
Check pins for pwr and gnd.
I'm betting it's the same-O-same-O in a different box(yawn).
That's why FSB is soooooooooooo great! (tony the tiger sound) heh heh
AG or modman will have the answer soooooooon.
Then we can all yawn together
Tone-to-the-Bone
- Greg
Thanks OSS 117.OSS 117 wrote:Thanks for the pics. I'm close to have a basic schem drawn, but I miss some connections for pin 8, 9 and 11 of the IC.
Pins 3, 12 & 13 are grounded.
14 seems to not be connected.
7 & 9 are connected.
8 & 11 are connected to each other and to one end of S1A rectifier.
Pots appear to be:
Vol: 100K Log
Slope: 2K Lin
Let me know what else you need, or if something doesn't make sense.
- juanro
Seems to me that there's a little mistake around C6... Pin 10 (emiter) should be connected to diode, and C6 is between this junction and CW side of Slope pot.
Juanro
Juanro
La única verdad es la realidad.
- teemuk
Thanks. There is indeed this mistake.juanro wrote:...Seems to me that there's a little mistake around C6... Pin 10 (emiter)
Reason: Previous post with wrong schem has been deleted (not edited, my mistake). Sorry...
- Hides-His-Eyes
what's C3/R9 doing?
- teemuk
Update. Seems like I also missed the part of the bypass that mutes the input when in bypass mode.
As far as I know, the R9+C3+transistor is somekind of a temperature compensation circuit. Beats me. There's more discussion of it in the threads about the Retro Channel "Fuzz".
Reason: Schem removed : see updated schematic below
- tube-exorcist
And what are the missing component values ?
- juanro
Teemuk: Your last schematic is missing the third pole of the 3PDT that switches the output (as shown, LEVEL pot and R6 are connected even when in bypass)
This is what I posted in the other tread (based on a very rough LTSpice simulation):
- A gain stage ("temperature stabilized") followed by a variable filter/buffer
Values for C4/C5 are currently unknown to me so I put two guesstimates.
- teemuk
I'm not entirely sure if that pole is used. There's no connection on the bottom side of the board and the switch is hiding the upper side. Anyway, it's just a bypass, you guys get the drift.
One more error I found is R6: it doesn't shunt to ground but is in series with the signal path, basically isolating the wiper from the output.
- modman
- a d m i n
Please, people, add a copyright notice to documents, using your name/username and a date. If you do not, anyone could easily claim copyright of this picture or file. With the notice in place, this is still possible, but the claim seems less likely to a third party (the hosting company)
Updated and slightly corrected schematic. Caps values still missing. LED circuit, switching and extra wiring corrected.
Reason: Schematic updated below.
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
shouldn't the bottom of switch S1b connect to the junction of R10 and R11
It was like this before, my mistake indeed, thanks bajaman!bajaman wrote:shouldn't the bottom of switch S1b connect to the junction of R10 and R11
- Retro Channel Trouble BoosterV4.gif (10.33 KiB) Viewed 2967 times
- method
I really do not follow what this part of the circuit is doing.teemuk wrote:As far as I know, the R9+C3+transistor is somekind of a temperature compensation circuit. Beats me.
Nor can I fathom the purpose of the darlington pair (pins 6/7/8 and 9/10/11). It looks to have VREF on the base and is acting as a buffer...for something.
