Blackout Effectors Mantra  [traced]
KindaFuzzy
Has thanked: 78 times
Been thanked: 254 times
Post by KindaFuzzy »
yes, the crappy treble response, and bass acting like a volume is easily fixed by moving that one connection, I actually had to do that on the first one I built and it works great. As for the funny voltages on the mosfet, dunno, maybe it's in backwards or your bias resistors are the wrong value.
Has thanked: 147 times
Been thanked: 138 times
some mosfets have different pinouts.
gigelmargel
Has thanked: 46 times
Been thanked: 12 times
Post by gigelmargel »
Thank you all for your kindness and help!!!
What I did, following your advices:
1. I modified the tone section as you said and now the tonestack works OK
2. I checked the pinout of the 2N7000 for 3 times (I tested the internal diode between S and D) and it's OK
3. I've tested 5 new 2N7000 and all had the same biasing problem.
4. I've checked the pinout of all 2N7000 using the internal diode between D ans S
Anyway, I will recheck all the resistors tonight.
Best regards!
KindaFuzzy
Here's some pics of the one I just finished for a friend (after correcting the tone stack boo boo).
gigelmargel
Woow...very nice work KindaFuzzy :)
I hope that I will have soon some time to try to debug mine :)
jwpartain1
Has thanked: 53 times
Been thanked: 59 times
Post by jwpartain1 »
What a freaking cool design, and clean build. Props! :thumbsup
neoflox
Post by neoflox »
Anyone got an idea about the low gain mod? (talkabout)
kismet78
Been thanked: 11 times
Post by kismet78 »
neoflox wrote:Anyone got an idea about the low gain mod? (talkabout)
We've done it a few different ways, but right now we're keeping it simple. Break the circuit after the 10k on the input and after the 100K just before the gain pot and wire a dpdt to bypass/add the first stage.
neoflox
Post by neoflox »
Cool, thank you!
joeboo88
my favorite amplifier: orange 30r
Completed builds: way huge lama, its8, eternity, ppp800, dod250, zendrive,colorsound overdriver, timmy,bluesbreaker
Has thanked: 263 times
Been thanked: 14 times
Post by joeboo88 »
Hey, Neoflox, did you build this with the vero layout you made?
Ebay is a fucker ~ Sinner - If this is something unique, then I'm a teletubbie ~also Sinner
neoflox
Post by neoflox »
Hi. No, I was eager and made a PCB right afterwards. It's 90% build but not yet verified either. Will post here when something works.
hazefuzz
Post by hazefuzz »
sorry for the newby question, but what is the difference between the GND and the GND(T) ?
Thanks for your helps
Nocentelli
Has thanked: 946 times
Been thanked: 831 times
Post by Nocentelli »
No difference, all ground points should be connected.
vanessa wrote: 20 Aug 2007, 17:51 You can't arrest someone for reverse engineering something.
dromilious
Post by dromilious »
I made the low gain mod with a 3pdt footswitch .the only problem is that i have the usual POP sound when i turn it on/off.any suggestions?
mirosol
my favorite amplifier: Been on Bogner for quite some time now.
Completed builds: Over 1000 and counting.
Has thanked: 162 times
Been thanked: 384 times
Post by mirosol »
Here's my stripboard layout, plus RNFR's schematic with the fix. As you can probably guess, i didn't read the entire thread and drew the first version of the layout with tonestack pushing the output from bass pot's lug 2. Made a crude fix on my build, so the layout posted on this post isn't verified yet.
Gimp'ed the tonestack output to where it should be...
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
gaffled
Post by gaffled »
Hey guys built the vero and everything works but only problem is I'm only getting 1.67 volts on the source of the mosfets. Otherwise all my other voltages match. So the gain seems a little less than the videos I've seen. I'm assuming but maybe I'm wrong this is why. I've used a ton of different 2n7000 and bs170's. My question is would playing with the source resistor change the bias. I would just do it but I'm out of town away from the build and want a game plane when I get back, I've never really messed around with biasing mosfets. Thanks mike
mirosol
Post by mirosol »
So the layout could then be called verified - Thanks man!
My own board has at least as much gain as the demos of the original unit, so your problem could be somewhere else too. My board has also a crude fix for the tone stack's output, so it's not 1:1 with the current layout.
But. If you want, you could try to tweak the 10K resistors from MOSFET sources to ground. Smalles value should give out more gain. You could just try placing some bigger value resistors in parallel to them to see if that works.
gaffled
Post by gaffled »
Ok thanks I'll start with the 10k source resistor. There is gain just not quite as much unless I dime my guitar volume. So I'll play around with the resistor and report back.
