Skreddy - P19
Posted: 28 Feb 2012, 21:56
Knicked these off Teh Gear Page.
I actually build my tone stacks by ear and then go back and enter the values I chose into Duncan's later, as a sanity check, to archive/catalog my tone stacks, and to develop those cool graphics for the webpage.briggs wrote:New SkreddyMarc - Do you use Duncan's Tone Stack calc to prototype your tonestacks or do you just go by ear then model it up, or a bit of both?
If I want a low noise Muff, those are the exact transistors I've been using. Maybe not my faves, but certainly very low noise.Skreddy wrote:...the goal of low noise...
...BC550 transistors...
Is there an "ideal" gain range for the BC550s? I recently went through almost all my trannies and measured the hFE (what's the proper abbreivation/capitalization?) so most of them are already labled. I have a Big Muff on the breadboard so it'd be cool to know which are the "ideal" ones. So far, my ears are really liking 5089s, but I remember the 550s being a close second.Skreddy wrote:Hint: it's a Big Muff design with tweaks inspired by Cornish P1. Pretty much shifted the Pig Mine into the direction of the P1, ending up with fully half the components changing in the process. For every 1 component I used that was the same thing as Cornish, about 4 are different. Not a clone of anything per se, just tweaked to my liking with the goal of low noise and clarity.
BC550 transistors
560pf nfb filter caps
200R emitter resistors
custom tone stack
Depends on the sound you're after plus the transistor type. 300Hfe is okay for 2N5133's but too low for most other types. Some of my builds use different gains in different positions, e.g., 600, 700, 800, different positions all in the same build. I think the BC550's in the P19 are pretty much in the 600 zone; but even though that's a moderate/lowish gain for most transistor types (e.g., would be quite low for a 2N5088), the BC550 has to be treated like it's very high gain (bigger emitter resistor and bigger nfb filter cap) to keep hiss down and tone mellow.dap9 wrote:Is there an "ideal" gain range for the BC550s? I recently went through almost all my trannies and measured the hFE (what's the proper abbreivation/capitalization?) so most of them are already labled. I have a Big Muff on the breadboard so it'd be cool to know which are the "ideal" ones. So far, my ears are really liking 5089s, but I remember the 550s being a close second.Skreddy wrote:Hint: it's a Big Muff design with tweaks inspired by Cornish P1. Pretty much shifted the Pig Mine into the direction of the P1, ending up with fully half the components changing in the process. For every 1 component I used that was the same thing as Cornish, about 4 are different. Not a clone of anything per se, just tweaked to my liking with the goal of low noise and clarity.
BC550 transistors
custom tone stack
Thanks Marc. Speaking of different values in different positions - is there a "rule" for that... ie, higher gain in Q1? Or just go by ear?Skreddy wrote:Depends on the sound you're after plus the transistor type. 300Hfe is okay for 2N5133's but too low for most other types. Some of my builds use different gains in different positions, e.g., 600, 700, 800, different positions all in the same build. I think the BC550's in the P19 are pretty much in the 600 zone; but even though that's a moderate/lowish gain for most transistor types (e.g., would be quite low for a 2N5088), the BC550 has to be treated like it's very high gain (bigger emitter resistor and bigger nfb filter cap) to keep hiss down and tone mellow.dap9 wrote:Is there an "ideal" gain range for the BC550s? I recently went through almost all my trannies and measured the hFE (what's the proper abbreivation/capitalization?) so most of them are already labled. I have a Big Muff on the breadboard so it'd be cool to know which are the "ideal" ones. So far, my ears are really liking 5089s, but I remember the 550s being a close second.Skreddy wrote:Hint: it's a Big Muff design with tweaks inspired by Cornish P1. Pretty much shifted the Pig Mine into the direction of the P1, ending up with fully half the components changing in the process. For every 1 component I used that was the same thing as Cornish, about 4 are different. Not a clone of anything per se, just tweaked to my liking with the goal of low noise and clarity.
BC550 transistors
custom tone stack
Higher gains give you a hotter sound (more "modern," tend to boost upper mids) and more dynamic headroom, but also more "compressed" as the quiet parts are amplified more, yeah? (but can boost hum and hiss too). And lower gains in a fuzz can saturate better and get more sludgy and more mellow and soft ("vintagey" sounding).dap9 wrote: Thanks Marc. Speaking of different values in different positions - is there a "rule" for that... ie, higher gain in Q1? Or just go by ear?
He does have a point there.gilmour_pugliese wrote:Hi, I read TRACED but I don't find the schematic...
Thank you very much... The P-1 seems to be a modified Ram's Head, and in that case I'm OK with my replica...Skreddy wrote:Pretty much started this project by approximating the Cornish P1 (sans input buffer) but tuned it to my ear and preferences--a few ceramic caps here and there, carbon comp resistors, some minor resistor value tweaks, smaller input caps to both help articulation and reduce 60 cycle pickup hum, and a big .33uf cap (instead of typical .1uf) between tone stack and output stage to help the bottom end breathe, as it is tight in the lows.
It's really not a P1 clone, just used that as starting point/guide to help me capture the right balance of clarity and aggression to nail The Wall tones, which I've always found challenging and irresistible. After I've sold a few more, I'll probably be in more of a mood to publish the schematic. Hopefully that won't take me long.
Nice tropical fish and 1/2 Watt cc's.gilmour_pugliese wrote:Thank you very much... The P-1 seems to be a modified Ram's Head, and in that case I'm OK with my replica...Skreddy wrote:Pretty much started this project by approximating the Cornish P1 (sans input buffer) but tuned it to my ear and preferences--a few ceramic caps here and there, carbon comp resistors, some minor resistor value tweaks, smaller input caps to both help articulation and reduce 60 cycle pickup hum, and a big .33uf cap (instead of typical .1uf) between tone stack and output stage to help the bottom end breathe, as it is tight in the lows.
Basically. I have a special "Skreddy" recipe for my clipping diodes for the slightest touch of asymmetric clipping that doesn't sound so different in the final mix (after 2 stages of clipping), but just adds a little bit of depth and character. I'd like to reserve that one last piece of info as my own signature touch. I suspect that older Big Muffs might coincidentally share a similar profile because older diodes were probably less precisely made and matched back in the day (much like older transistors tend to vary hugely in gains compared to their new counterparts).Seiche wrote:what are D1-D4? Just 1N4148s?
