...well! Will see. Should be here any time. I hope to see it gooped, I want to become Degoop DoctorWe approached the Manifold Drive a little differently. We didn't just copy an old proven design, instead we had specific goals in mind and designed a new overdrive circuit from the ground up to meet our expectations.
Resonant Manifold Drive
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
From www.resonantelectronic.com website:
- sinner
It sounds lush as hell indeed, Big Muff(ish) to my ears - and that is what I was expected, and BTW this is what daddy loves
- ppluis0
Hi there,
Perhaps any member of this forum if live in USA can subscribe to the Tour Box offer and have 10 days to peek inside a unit or, at least, take some gutshot images prior to send it to another participant.
This proposal, to send several pedals to travel the country, is very innovative from the marketing point of wiew. At least to me.
Did You get it?sinner wrote:From http://www.resonantelectronic.com website:
I hope it is gooped, so You have more work to do
I have only picture of the trace side of the PCB:
- sinner
No idea Robert I'm working till late today, I see when I get home. Do you like this obscure pedal I've sent you in returnSikor wrote:Did You get it?sinner wrote:From http://www.resonantelectronic.com website:
- sinner
Got it!
No goop
No BMP
I love everything about this pedal. Build quality, the look, the sound...
More later on
No goop
No BMP
More later on
- sinner
Picts
- sinner
Volume - A500k Alpha 16mm
Gain - A10k Alpha 16mm
Q1 - 2N5457
Q2 - MPSA18
Q3 - MPSA14
Q4 - 2N5457
Q5 - 2N5457
D1 - silicon diode
D2 - silicon diode
Sockets are:
J1 - In Jack:
- red: Tip
- yellow Slave
- green: Ring
J2 - Out Jack:
- yellow: Tip
- green: Ring
J3 - Power Socket
J5 - Gain Pot
J6 - Volume Pot
J7A/J7B - DPDT On/Off/On (switch between Dark-Bright-Flat mode)
Q1 - 2N5457
Q2 - MPSA18
Q3 - MPSA14
Q4 - 2N5457
Q5 - 2N5457
D1 - silicon diode
D2 - silicon diode
Sockets are:
J1 - In Jack:
- red: Tip
- yellow Slave
- green: Ring
J2 - Out Jack:
- yellow: Tip
- green: Ring
J3 - Power Socket
J5 - Gain Pot
J6 - Volume Pot
- sinner
Not much today, other things to do. I'll back to it
Yes, more than I thought actually!sinner wrote: No idea Robert I'm working till late today, I see when I get home. Do you like this obscure pedal I've sent you in return
If only the Gain knobs would worked more even.
I mean, in the first 90% it's not happening a lot
and than in the last 10% there is huge change
BTW have You found the Englishman?
I'm glad You like it!sinner wrote:Got it!
No goop
No BMP
More later on
It's interesting overdrive. I was using it mostly as a "gain and grit" booster for other pedals
hi, I traced some more bits on your tracing pic. Not much, but I hope it helps.sinner wrote:Not much today, other things to do. I'll back to it
- sinner
I did far more, but thanks Be patient
- sinner
Lack of general interest leads me to conclusion that there is no rush, so I've took my time and spend it on projects I was working on earlier before it arrived. I'll try to do something with it over weekend
- Bill_Mountain
Trust me when I say there is plenty of interest. I almost asked for an update yesterday but I wasn't sure of the nicest way to say it.sinner wrote:Lack of general interest leads me to conclusion that there is no rush, so I've took my time and spend it on projects I was working on earlier before it arrived. I'll try to do something with it over weekend
- Bill_Mountain
I think we're all in agreement that claims of originality can't be ignored.Steven_M wrote:Yes indeed! This pedal is killer! No lack of interest on the part of anyone here.
