+10bajaman wrote:On the contrary - no need to carve the block of epoxy up - if we could just get some component values and better board pictures we should be able to reverse engineer this device and make some educated guesses as to what is in the epoxy block.I'm not prepared to carve that block of epoxy up yet. The whole thread is for naught
Blackstone Appliances - MOSFET OD (2SV3.12) [ goop-alarm ] [traced]
- oscarv77
- briggs
- noelgrassy
- my favorite amplifier: MOTS Magnatone & Trainwreck
- Completed builds: Tonebender Mk II w/ 3 OC75's, Burns BuzzAround w/NKT 275,Rangemaster w/ OC44, Fuzz Face w/ SKS363's, CJOD, Harmonic Percolator w/2N404A & 2N3635(vintage correct box,sliding pots, 1%glass resistors),Stack-O-Dimes & Whipple Wahs,
- Has thanked: 11 times
- Been thanked: 3 times
I've been busy with other stuff & had dropped the ball on this one. I'm gonna shoot some pics of uniform dimensions and lay it out for stitching back together. I'll post as many values as I can get off the PC later tonight. Thanks for your patience and please remember, this will probably take summoning all your powers because the epoxy block remains intact. It's also where the MOSFET resides.
- oscarv77
Analogguru I choose you!!noelgrassy wrote:I've been busy with other stuff & had dropped the ball on this one. I'm gonna shoot some pics of uniform dimensions and lay it out for stitching back together. I'll post as many values as I can get off the PC later tonight. Thanks for your patience and please remember, this will probably take summoning all your powers because the epoxy block remains intact. It's also where the MOSFET resides.
Bajaman, +10 attack!
- Silent Fly
Has someone managed to go make any progress in dissecting the Blackstone-OD?
I got the chance to test the blackstone a day, dissected it and took way too much pictures, enjoi!
Stef
https://s70.photobucket.com/albums/i94/ ... lackstone/
Stef
- oscarv77
stefcuypers wrote:I got the chance to test the blackstone a day, dissected it and took way too much pictures, enjoi!
Stef
Nice job with the pictures!
- Silent Fly
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
Whatever is inside that block will most probably be as anticlimactic as what I found inside the HH valve sound module
chisel anyone
chisel anyone
- Silent Fly
How the heck do you degoop that thing? It looks an interesting challenge...
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 281 times
take that to hospital and X-ray it......
- bajaman
Or a dentist - good idea - but could be costly - unless you do that sort of work for a living - multiple X - rays neededtake that to hospital and X-ray it
- culturejam
- bajaman
bump
- theyear2042
i believe torchy already has the schem for the BS OD - best to ask him for his copy before putting in all the hard work of reversing one.
im under the impression that it is an obsidian converted to n-channel (reverse the polarity and caps).
id be interested in seeing the schem purely from a technical point of view - im not too keen on the clips on youtube
2042!
2042!
- earthtonesaudio
What I want to know is, where do you find the pots and especially the knobs used in this thing?
