A Golden Ticket?madbean wrote:There was another little surprise in there, which I will also share.
Blackstone Appliances - MOSFET OD (2SV3.12) [ goop-alarm ] [traced]
- soulsonic
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
don't keep us in suspenders
great work brian
great work brian
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 281 times
madbean wrote:Looks like two 1/4W resistors and three 1/8W resistors to go along. I'll finish this up tomorrow. There was another little surprise in there, which I will also share.
It's a double sided board, too. I might just desolder the whole thing.
- RnFR
man, these suspenders are really uncomfortable.
- soulsonic
Awwww.... better write them now and order a module before they go back on the deal!
- briggs
- RnFR
at least they said please!
Hey folks,
could any of you explain me in a short and understandable way, what this little "black box"-platine does excactly?
I have got a Blackstone on my board, and I'm really happy with it...
Thanks a lot
Thanks a lot
- kusi
hi,perregrintuk wrote:Hey folks,
Thanks a lot
the "main-distorting-circuit" is on this gopped pcb. probably cmos-inverter-clipping.
thanks to mr. madbean for the funny pictures
regards, kusi
Hey Kusi,
so what I thought is done by transistors is at the Blackstone inside this chip, like a lot of transistors in one chip, or just like diodes?
Is the way Blackstone does it, a clean and good way or are there some "it could be done better" thoughts in your head?
While I was using the pedal I thought a couple of times about a chip inside the pedal, because if I used the "mid"-pot I always recognized besides the increasing of the mids that another drive character which goes strongly into the typical JRC4556 drive sound came up. Cool pedal...I love it.
- briggs
The circuit is using a CD40XX series chip, the cmos inverters that are in the chips are made up of mosfets. There is also an opamp in there too, you can see on the pictures. My guess is that this will be buffering the output of, and controlling gain to, the CMOS chip. I'm expecting the inverter stages to be cascaded into one another - emma reezaFRATzitz style.
- culturejam
Similar to the Runoff Groove Double D?briggs wrote: I'm expecting the inverter stages to be cascaded into one another - emma reezaFRATzitz style.
http://www.runoffgroove.com/doubled.html
- briggs
Yeah, something resembling that sort of design, with an op amp buffering any tone control networks.... I dunno, just a guess.culturejam wrote:Similar to the Runoff Groove Double D?briggs wrote: I'm expecting the inverter stages to be cascaded into one another - emma reezaFRATzitz style.
Sounds good.
@madbean: Will you try to reverse engeneer....?
Slow and exact, the best way to go. You're the man madbean!
