Page 2 of 2
Re: Wampler Sovereign Distortion
Posted: 25 Jul 2016, 23:50
by MoonWatcher
Bloodman wrote:I have already traced this pedal
Please post your schematic from your tracing.
Posted: 26 Jul 2016, 05:22
by Bloodman
I'm a Chinese, this may take a little time to sort out my documents.I want to write something here recently about this pedal .as you know,maybe I need to translate my idea to english
Posted: 26 Jul 2016, 17:27
by 287m
Bloodman wrote:I'm a Chinese, this may take a little time to sort out my documents.I want to write something here recently about this pedal .as you know,maybe I need to translate my idea to english
we always wait you
and i think for almost member here, the language of your idea is just scheme only, explanation later :secret:
Posted: 26 Jul 2016, 18:37
by J0K3RX
Bloodman wrote:
MoonWatcher wrote:
Bloodman wrote:The monolithic circuit and parameters of the sovereign are very similar with the pinnacle
Indeed. It seems that there are a bit of similarities, in particular, with it and the Pinnacle LE. The latter was traced out in what I think was a Pinnacle II thread. So I went and dropped in the capacitor values for the LE, and then looked at the Sovereign. I tried to label what I thought might be the cap equivalents.
I figured that until someone has one to trace, that the next step would be figuring out the resistor values, and then they could be cross-referenced to the Pinnacle as well.
This seemed like as good a place as any to start. I hope it helps.
Re: Wampler Sovereign Distortion  [traced]
Posted: 28 Jul 2016, 12:41
by Bloodman
:popcorn:
I don't know how to upload the PDF file
Posted: 28 Jul 2016, 12:44
by mlp-mx6
In the right tab below the text box it says "Upload attachment" - use that.
Posted: 28 Jul 2016, 12:49
by Bloodman
mlp-mx6 wrote:In the right tab below the text box it says "Upload attachment" - use that.
Thanks ,I got it
Posted: 28 Jul 2016, 12:55
by Bloodman
This is the second version of Pinnacle
Posted: 15 Sep 2017, 19:54
by mwelch55
Referring to the schematic posted last year, does anyone know the purpose of the MOSFET in the power section of the schematic? I have never seen that before.
Mike
Posted: 16 Sep 2017, 00:33
by POTL
Mike
Hi
this is reverse polarity protection
Posted: 25 Sep 2017, 23:23
by Ice-9
I pretty much use that Mosfet polarity protection in most of my builds. You can read how it all works on R.G's Geofex site.
Posted: 01 Jun 2018, 16:30
by ray86
sound great !!!
Posted: 12 Sep 2018, 20:43
by annaelyse_win
Recently picked up a broken Sovereign for free from someone.
However, some parts were taken out of the circuit and the pedal dissembled.
I've managed to replace the missing parts and attach the input, output, and power supply correctly..well...hopefully.
Can anyone give advice on how the original schematic wires up the foot switch and input and outputs?
Posted: 31 Dec 2018, 16:33
by Bloodman
annaelyse_win wrote:Recently picked up a broken Sovereign for free from someone.
This schematic is the original pedal that I duplicated, but as far as I know, there are many versions of the pedal circulating in the market.it is difficult to determine whether the circuit you see is consistent with what I see.
Hope to be of use to you,Forgive my poor English
Posted: 06 May 2019, 10:34
by coxy
Hi all,
I know this is an old thread but Ive been trying to get this circuit working for a while now and having exhausted all the usual troubleshooting stuff I was wondering if anyone thought the 10 ohm resistor in the power section could be causing an issue?
I know in the pinnacle the same resistor was actually burning up for some people from being too low a value, and in this circuit it is connected to the IC, I was wondering if maybe the IC was being fried each time as a result of too much current?
Im not too experienced so am most likely talking shit but I know a few people have had a similar issue to me with this build (too low gain)
Let me know what yas think..
Posted: 06 May 2019, 10:58
by plush
coxy wrote: I was wondering if anyone thought the 10 ohm resistor in the power section could be causing an issue?
No. Unless it is not 10 ohm and has way greater value.
coxy wrote: I know in the pinnacle the same resistor was actually burning up for some people from being too low a value, and in this circuit it is connected to the IC, I was wondering if maybe the IC was being fried each time as a result of too much current?
This resistor burned because some dum-dums shorted VCC to ground somewhere.
Posted: 06 May 2019, 18:22
by coxy
haha fair enough thanks for the response
