I couldn't resist the temptation and opened the little bugger minutes after trying it. I was expecting goop but to my surprise it was clean so here are some pics (click to enlarge)
It's a single transistor design based on one that has been floating around for god knows how long. I built one of those with a 2n3904 so I did a bit of comparison and found that I prefer mine but that's just my opinion. The Fryer unit has more gain which may have to do with the higher hfe of the BC239. it also has some more bass due to the bigger input cap. But other than that they are pretty much the same thing.
The only thing I just couldn't get was the value of the ceramics (C8 & C9). I believe they are 10p but it's really hard to read the inscription.
No, absolutely not. Its the different value of R5 (2k2 vs 2k4) and probaably the bigger input cap.
You are right, since the emitter is fully bypassed at "high" frequencies decreasing R5 would indeed boost the lows somewhat. Sorry about that, I didn't noticed that change on the schematic. Either way you didn't have to be that aggressive about it now did you?
On the other hand my unit has a 10k pot in the collector and a 2k4 emitter resistor.
Gentlemen, I think you are mistaken. The Treble Booster Deluxe Plus Ultra version comes with a footswitch, and a volume knob. The Red Dot Ad Infinitum version bless us with an indicator led.
Gonzo wrote:The Fryer unit has more gain which may have to do with the higher hfe of the BC239.
Nope - the overall gain is determined by the ratio of the collector resistor to the emitter resistor. Gain is (roughly) Re so you can easily change the basic gain of the thing. The ceramic capacitors will be more likely to be 100pF or even bigger - 10pF wouldn't do anything.
MoonWatcher wrote:
Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
