Throbak Overdrive Boost Schematic  [traced]
mxrmxr
Been thanked: 42 times
Post by mxrmxr »
skywise
Has thanked: 48 times
Been thanked: 21 times
Post by skywise »
Kinda seems like a waste of a germanium transistor just to use it as a diode. :scratch:
Bernardduur
Has thanked: 86 times
Been thanked: 555 times
Post by Bernardduur »
It sells :)
Hmmmm, were 2N2222A's ever used in the Colorsound Overdriver???/ That as they state on their website that the use the EXACT same transistors as the original.........
Commercial talk I guess :)
beedotman
Has thanked: 402 times
Been thanked: 390 times
Post by beedotman »
skywise wrote:Kinda seems like a waste of a germanium transistor just to use it as a diode. :scratch:
Those could be very low or very high gainers and/or leaky ones, useless for other functions...
Ben N
Has thanked: 78 times
Been thanked: 29 times
Post by Ben N »
Thanks, I've been looking forward to seeing this one. I admit I'm a bit disappointed that the Ge is just a clipper, and "Pre-Gain" is just a switchable input attenuator (at the cost of the original circuit's volume control), but what works works, I guess. The schem doesn't say, but I'm assuming 9v?
silverface
Been thanked: 9 times
Post by silverface »
Are you sure the resistor on the Bass pot is 3k9 ? On most other schematics of the original overdriver/powerboost it's 39k.
mxrmxr
Post by mxrmxr »
silverface wrote:Are you sure the resistor on the Bass pot is 3k9 ? On most other schematics of the original overdriver/powerboost it's 39k.
See for yourself....
bgobeske
Post by bgobeske »
Nicely DONE!!! Quick question the board shows 4 trimpots. is one of these the 500k pot showed in the schematic. if so dose the 3rd pin of this pot go to ground or is it use like the three other trimmers?
mictester
Has thanked: 27 times
Been thanked: 784 times
Post by mictester »
I do it all the time - it's a great way to use up leaky transistors!
Nocentelli
Has thanked: 1016 times
Been thanked: 870 times
Post by Nocentelli »
gigelmargel wrote:Hello,
Maybe I am stupid, maybe I am blind, but I can't see any schematic here :)
Can anyone help me?
Thank you very much!
Seems to have been pulled by the original poster: Thankfully Mirosol did a vero layout -
http://tagboardeffects.blogspot.co.uk/2 ... boost.html
...so it shouldn't be difficult to re-draw.
vanessa wrote: 20 Aug 2007, 17:51 You can't arrest someone for reverse engineering something.
Nocentelli
Maybe, the last post from mxrmxr was two months ago, so while waiting for it to show up again you could compare mirosol's layout to the stock colorsound overdriver schem and note the few differences.
Has thanked: 506 times
Been thanked: 1830 times
Ripdivot
Been thanked: 77 times
Post by Ripdivot »
Thanks Baja
snofla1900
Has thanked: 83 times
Been thanked: 7 times
Post by snofla1900 »
Oh I see you already have it. I just sent you a copy.
What it reminds me of is the Coloursound overdriver, just compare.
Alf
tube-exorcist
Has thanked: 173 times
Been thanked: 65 times
Post by tube-exorcist »
If the schematic is correct and the pedal really wired this way then it is a piece of junk. Think of the pre-gain-poti fully down but bypassed..... But what does one expect from a solder-jockey clone.
roseblood11
Has thanked: 349 times
Been thanked: 305 times
Post by roseblood11 »
...and in both positions of the switch the 2M2 at the input would be useless.
I can't believe that this schematic is correct.
V1nce69
Completed builds: Veroboards builds:
Wampler Ecstasy
Creepy Fingers Doomidrive
Black Arts Quantum Mystic
Roger Mayer Voodoo Bass
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
Fulltone 69 (GGG kit)
Russian Big Muff (Musikding kit)
EHX Bassballs (home etched using Topopiccione layout)
BJFE BBOD (home etched, thx FSB)
Triangle Muff (Guitar PCB board)
Deluxe Bass Fuzz (home etched,gausmarkov.net layout)
Clone Theory Chorus (Celeste pcb from lectric-fx)
Cornish G2 (home etch, layout thx FSB)
Shin-Ei FY-2 Ge version (home etched, own layout)
Klon (Aion Refractor pcb)
Mutron Phasor II (home etched, layout thx JohnK)
Sunny-T (pcb by guitar pcb)
Rocket Overdrive (pcb by Pepers' pedals)
Sonomatic Deluxe Tape Delay (pcb by Skidmark)
Black Arts Quantum Mystic (adapted storyboardist layout)
Has thanked: 36 times
Been thanked: 96 times
Post by V1nce69 »
I successfully built this pedal using the layout from tagboardeffects. I can confirm that this layout works and that the pedal sounds really fine.
As for me less wiring from the board, the better, I made some slight changes to the layout:
- I didn't use the dummy connection to the board (PGSW1/Pregain 3), thus 1 cut less. I wired the Pregain switch 1 directly to Pregain pot 3.
- there's only 1 ground wire going out of the board; Pregain1, Gain 1&2 and Volume 1 are daisy chained to ground on the DC jack.
- I used a 3PDT for the Boost switch as I didn't have a DPDT.
The wiring itself is kinda tricky and it took me quite a while to figure it out. I made 3 or 4 different versions before getting it working the way it should.
Actually it was my first attempt to build on veroboard…
So I thought I would post the layout I used and a few pics of the build itself.
Layout:
layout
layout
Outside:
outside
outside
Inside:
inside
inside
Board
board
board
rocket8810
Been thanked: 23 times
Post by rocket8810 »
I've built this using the same layout on tagboardeffects and it fired out right away and sounds great. A there is one anomaly that bothers me. Whether the boost is engaged or not the pregain pot will effect the signal. Now, it's not a big change when the boost is off, it's much more drastic when the boost is engaged. I would have thought that when the boost is off the pregain pot is out of the circuit.
Nick123
Post by Nick123 »
Using DPDT instead of a SPDT switch would decouple the pregain pot from the rest of the circuit.
rocket8810
hmmm, i wired it with a 3pdt switch since i didn't have any dpdt switches laying around, cause i wanted to have an led indicator too. i wonder if that's the issue. i may have to go back and take a look at it, but for now it sounds good to me.
