Walrus Audio - Deep Six Compressor  [traced]
roctopus
Post by roctopus »
Here are a few pics I took of the new Walrus Audio Deep Six Compressor if anyone cares.
Mbas974
Has thanked: 39 times
Been thanked: 40 times
Post by Mbas974 »
Cool, seems something already seen on this forum... right Melinb ?
while whether you want to trace it... better heve picture of the other side as well.
mmolteratx
Has thanked: 93 times
Been thanked: 619 times
Post by mmolteratx »
It's much more likely to be a Ross-alike with a charge pump.
mictester
Has thanked: 32 times
Been thanked: 830 times
Post by mictester »
Mbas974 wrote:Cool, seems something already seen on this forum... right Melinb ?
Nope. It's a Dynacomp using a 13600 / 13700 like the Yamaha version of the circuit. The other side of the 13600 is used as a fixed-gain bypass amplifier in the Yamaha.
roctopus
Post by roctopus »
more pics
lukatosh
Has thanked: 33 times
Been thanked: 186 times
Post by lukatosh »
Hi everyone!
well... i'm attempting to trace this pedal.
Its pretty much like the BYOC 5 knob Comp although i've noticed a few things to discuss:
1.- 1uF "NP" (looks like electrolytic), 10uF"NP" and 4.7uF"NP" are used in positions where electrolytics caps were used originally in the dynacomp. can we just use polarized caps like in the Dyna?
2.- only half of the LM13700 is used, the other half is not connected.
3.- The blend circuit portion is a little bit tweaked; specially the last stage uses a fairchild 2n5484 (Image posted). I've read about using a 2n5457 as a replacement but:
Walrus Audio Deep Six Compressor schematic
3.a) why do they used this design instead the proposed by BYOC?
3.b) how do the 2n5457 will work?... we can just replace it or the circuit needs to be tweaked! (of course after checking the 2n547 pinout).
3.c) Do you suggest maintain this JFET or go back to the design proposed by BYOC?
That's it... I'll keep on working!
Please, excuse my bad english... Best regards from Chile!
lukatosh
Post by lukatosh »
[ Image ]
Thanks!!
mictester
Post by mictester »
You can substitute the FET - pretty much any n-type will work in that circuit.
Your other question - why they did the blend like that - is because they can! It'll work OK and will be quiet because there's no DC differential on the pot.
audioguy
Has thanked: 22 times
Been thanked: 7 times
Post by audioguy »
Did this project ever get completed with a layout?
lukatosh
Post by lukatosh »
Nop... i've just traced the pcb!
micahvdm
Post by micahvdm »
good day!
any chance of a pcb layout or complete schematic?
storyboardist
Has thanked: 84 times
Been thanked: 224 times
Post by storyboardist »
Here's a schematic based on the BYOC schem with the changes noted by lukatosh. Working on a PCB
storyboardist
Alrighty, here's the perf/pcb layout. I originally wanted on-board pots (and you could still board-mount 2 of them), but trying to keep it 1590B-friendly squashed those dreams. haha Guess there's a reason most modern circuit boards are multi-layer :wink: I drew the board to use 1µ tantalum caps to save space and for lower noise, fyi.
friedtransistor
my favorite amplifier: Marshal Class v
Completed builds: Mad Professor Deep Blue delay, Mark Hammer's Chaos Fuzz, and an overdrive for my friend at church.
Been thanked: 25 times
Post by friedtransistor »
Hmm. Schematic look like the dod 280 that I built a while ago, except using a ota instead of an optocoupler, and mixing the dry and wet signals.
On the mixng part, does anyone have clips of that? Cause I've never heard a compressor mixed with dry, just straight wet. [smilie=a_yumdumdoodledum.gif]
For all you starwars fans...
Sorry, downsized by request.
Did I mention I love bass?
kaeisy
Has thanked: 17 times
Post by kaeisy »
Look here:
newly
Post by newly »
storyboardist...is the one that using BA6110 an actual Deep6? I open up one last night, it has JRC13700 instead.
storyboardist
newly wrote:storyboardist...is the one that using BA6110 an actual Deep6? I open up one last night, it has JRC13700 instead.
Sorry, just now saw this. The BA6110 is left over the BYOC 5-Knob Comp. Guess I forgot to swap it out for the 13700. Fix that and working on redoing the layout. The layout I posted before has been verified, though it's been pointed out to me that the VrefA has a minor error (56k to ground should be 27k). Here's the updated schematic and I'll be working on a new layout with the correct 13700 chip.
storyboardist
Don't know how i missed this before, but there isn't a tone control on the Deep Six that there is on the BYOC. I would assume it follows the original Ross Comp schematic in that area. It also runs off 18v, so I've updated the schematic to reflect that as well. I would assume the charge pump is a typical 1054-style, but I didn't include that.
storyboardist
New layout. A bit bigger than the old one but the pots can be board mounted and there are fewer jumpers.
Joel Tavares
Post by Joel Tavares »
Hi, is this layout verified? Thnks
