Oddfelow Effects - Caveman Overdrive  [traced]
jreeves47
Has thanked: 55 times
Been thanked: 24 times
Post by jreeves47 »
flavor of the month at the polishers forum
pic from ebay
jubal81
Has thanked: 48 times
Been thanked: 30 times
Post by jubal81 »
Funny. Id've sworn from listening to the demos that it would have been 4049-based.
FiveseveN
Has thanked: 137 times
Been thanked: 70 times
Post by FiveseveN »
Maybe it's a 4049 cut in half! [smilie=a_jester.gif]
No close-up yet?
Lawnchair
Been thanked: 16 times
Post by Lawnchair »
The descriptions posted on TGP remind me of the CJOD. No idea of the topology.
gtrplaya101
Post by gtrplaya101 »
Heres another close up: (Photo not mine)
I'm seeing tl072??
single clipping diode
dual transistors
humm
mmolteratx
Has thanked: 97 times
Been thanked: 606 times
Post by mmolteratx »
FET clipping in the feedback loop. It's a boring op amp clipper with basic frequency shaping. Maybe Zen Drive ish. Not worth tracing, IMO.
Manfred
Has thanked: 1155 times
Been thanked: 762 times
Post by Manfred »
mmolteratx wrote:FET clipping in the feedback loop. It's a boring op amp clipper with basic frequency shaping. Maybe Zen Drive ish. Not worth tracing, IMO.
I agree with you.
DrBoogey
Been thanked: 7 times
Post by DrBoogey »
Hi guys
I looked inside one and I saw two 2N7000 and one TL082, that reminds me of something :scratch:
Oddfellow Caveman Drive :D
mirosol
my favorite amplifier: Been on Bogner for quite some time now.
Completed builds: Over 1000 and counting.
Has thanked: 162 times
Been thanked: 383 times
Post by mirosol »
I agree with you.
Nothing is not worth tracing. In fact, more of a ripoff, more important that it is traced.
+m
http://tagboardeffects.blogspot.com/
http://mirosol.kapsi.fi/
"No such thing as innocence" -Iron Chic
DrBoogey
Post by DrBoogey »
I traced a unit from a collegue and my guess was right, its a slightly modded Fulltone OCD
I have drawn the changes in the OCD schematic I found in the net
The Diode is not a 1N34 or other germanium, maybe a shottky diode
I breadboarded the circuit and compared with the original unit, it sounds absolutly the same as the original Caveman Drive (differences: I used a TL072 and a BAT85 for the diode)
mirosol
Post by mirosol »
This is exactly what meant with my comment above. I think it's important that we uncover blatant ripoffs that result in disinformation and well, crap like this:
http://ztalk.proboards.com/thread/60746 ... -overdrive
Quote: "This sounds like an awesome pedal. And, also sounds like an original design. I wonder if this pedal will achieve the same street cred as the Timmy. I'm hoping yes - because I love the idea of people coming up with original designs and becoming successful with them. The question is . . . how long will the $132 price tag last?"
No. I don't want to see anyone becoming successful with changing couple of resistor and cap values in existing design. Seems like the price tag got a bit questionable a few moments ago, when DrBoogey posted his trace.
+m
IvIark
Has thanked: 600 times
Been thanked: 608 times
Post by IvIark »
DrBoogey wrote:I traced a unit from a collegue and my guess was right, its a slightly modded Fulltone OCD
Cool. How is the Boost switch wired in the original? I can see in the gutshots that two poles are used but by the schematic you could obviously do that with one pole.
mirosol
Post by mirosol »
I believe the other pole is for the "Boost" indicator LED.
IvIark
Post by IvIark »
mirosol wrote:I believe the other pole is for the "Boost" indicator LED.
Ha ha, aah right, I didn't realise it has an indicator. Should have been bloody obvious really
DrBoogey
Post by DrBoogey »
Yes, its the LED indicator :wink:
IvIark
Post by IvIark »
This should cover it
mmolteratx
Here's a redraw of the schem with a slightly less retarded boost control. Might do up a PCB later today.
mmolteratx
Did this pretty quick, but I looked over it and it looks good, as long as the schematic is good. Uploaded to OSH Park. I don't guarantee that it works, but it's very likely that it does. Might be up to organize a group buy after it's verified and if there's enough interest. Will fit in a 125B for sure with battery and everything. Might even fit in a 1590B with a bit of ingenuity. Plus it doesn't look like a monkey designed it.
https://oshpark.com/shared_projects/uhVgxqEH
mmolteratx
PCB above is verified.
zedsnotdead
Has thanked: 31 times
Been thanked: 52 times
Post by zedsnotdead »
Hi guys, sorry for the necro-post.
I built this thing some days ago, and I'd like to share with you some thoughts.
Here it is, built on mmolteratx OSHpark PCB (excelent work, thanks a lot! :D there's only just one thing - please check note @ end of post):
Now a few notes regarding the sound.
1- I compared it vs OCD. Caveman seem a little darker sounding, but tweaking the tone control they sound almost identical.
2- I used a B100K pot for boost control. Only at around 80% CW you start to notice a "boost on/off" difference. Lower than that rotation it doesn't do much for boosting the signal. What I mean is if you have the boost pot @ 50% and step on the "boost" footswitch you will hear almost no difference in volume. You only get it significantly above 80%.
So what I was wondering is:
a) how do I make it less dark sounding? Should I change the tone cap? Should I change the pF cap on the feedback? Both??
b) do you think that using a B50K pot for boost control could give a better "range spread" for it?
Thanks!!
@mmolteratx
Boost pot/trimmer connections are backward. 1 is 3, and vice versa :)
