swt wrote: ↑20 Jul 2020, 21:16
What's the purpose of those parallel caps? C12 & c13? I'm asking because if you connect c12 to accent 1 and leave c13 as is...it works as a high presence filter. Did someone try this?
Mostly you put 2 caps in parallel to get a value which is not (at all) available or very expensive to buy. In this case they form a replacement cap of 267nF which is a close one to the not that standard in (e27) 270n caps. Sometimes it is cheaper for manufacturing to use e12 values when outsourcing to... china
But if you want to safe space... use a 270n
I only give negativ feedback and y'all love it! PCB shop
I've seen this before, but right now it takes ages to get orders from the US to EU, that's why I've created own PCB layout and ordered it. Another thing, I've placed all controls the same way as it was on Mad Professor version of the pedal.
[/quote]
make sense. You probably order from china, it is preatty fast indeed for 10 pcb and cost not that much.
Value of C5 is for sure 100 nF? It seems to be huge.
I've built one using fuzzhead's vero, but it works strange: I have a lot of clean signal and a weak distorted signal in background. I have no TLC2272, but I tested other op amps (AD712, LM833, OPA2604), with the same result.
