Blackout Effectors - Fix'd Fuzz [traced]
- tuemmueh
Hi there,
I just found this pedal: http://blackouteffectors.com/ ... the FIX'D FUZZ. Sounds somewhat interesting, maybe anyone has some informations?
4 transistors stages ... first thought: BMP. After reading the manual my guess is a tonebender with an added BMP-style tone-control including the last transistor-stage of the BMP.
But maybe someone knows more about it?
.... Timm
.... Timm
- MoreCowbell
- Transistor Tuner
It's a monster of a fuzz/boost and a very challenging build. Without going into too much detail before it's released, it's a very versatile small box (1590B) with a bypassable boost (that gets a little od grit at higher settings) which can then cascade into either the 1st fuzz circuit or the 2nd (different) fuzz circuit OR BOTH. Plus some other nice little surprises. Need I say more about it's versatility?
- MoreCowbell
- Transistor Tuner
No biggie...i figured you just didnt read the thread at HCtuemmueh wrote:. . . allright. I missed the 2 most important sentences. Thank you.
- RnFR
it's pretty cool how it switches sections in and out like that. you think the sections are paraellel or series? what's the best way to do this?
- soulsonic
Welcome!kismet78 wrote: I'm happy to answer any questions
I have a question; in the description of the Musket Fuzz, you make reference to another fuzz called the Civil War. What can you tell us about that; is it an earlier fuzz you no longer make? Something based on any of the existing circuit memes we see often?
The Civil War was a nickname given to the the very first Russian Big Muffs due to the blue/gray colour scheme. These preceded the green Russian muffs. The Musket Fuzz is going to have an (improved) stock mode and a higher-gain mode.soulsonic wrote:Welcome!kismet78 wrote: I'm happy to answer any questions
http://www.pisotones.com/BigMuffPi/psst ... rsions.htm
- soulsonic
Huh... I learn something new every day.
- irmcdermott
really sorry to bump an old thread. does anyone have a schematic for either the Fix'd Fuzz or the Muskett. i really dig them both and see he even builds "the twosome" with both in them. just thought i'd ask. thanks.
ian
ian
- RnFR
i found this- could be related?
- fuzzfixx.gif (21.21 KiB) Viewed 4521 times
What type of fuzz is the second fuzz? It sounds rather cool. Is it a clone or similar to another standalone pedal?
