Seymour Duncan - 805 overdrive
- Ichabod_Crane
The schematic is in the doc, now:
https://www.pedalpcb.com/docs/SeyfoamOD.pdf.
I tried to draw a layout.
NOT VERIFIED
Warning: Two cut track even under the transparent 18nF.
Tell me if you see something wrong.
(Probably I can't build it soon.)
NOT VERIFIED
- Manfred
- Has thanked: 1671 times
- Been thanked: 1344 times
Hi Ichabod_Crane
checked your vero-layout and found the errors I marked in the image.
To trace them I made a copy of your layout with the Lochmaster 4.0 layout program.
This program provides a trace function which highlights the selected connections in color.
I have moved the jumpers that used the common holes and are located under the parts.
I am not happy with this kind of connection, because I have had bad experiences with it in the past. The redrawn schematic according to the Vero layout: Lochmaster 4.0 file:
- Ichabod_Crane
Thank you, Manfred. You're right, that layout was my old version, indeed I corrected those mistake just like you said.
Here my layout:
I didn't try Lochmaster 4.0, I don't like too much how the layout is drawn, but the highlight function can be useful.
I guess I never got problem with shared hole and under part jumpers, especially when I use the thinner lead cut from the old resistors by Tayda.
Here my layout:
- Manfred
No worries this is not a common problem but my personal problem.I guess I never got problem with shared hole and under part jumpers, especially when I use the thinner lead cut from the old resistors by Tayda.
