K&K Trinity Preamp  [traced]
Sogum92
Been thanked: 13 times
Post by Sogum92 »
K&K Trinity Preamp /
2 Piezo & Mic channel Acoustic Preamp
https://www.kksound.com/products/trinitypreamp.php
Dear,
I trace out K&K Trinity Preamp
Sorry, It is no Schematic, Only Layout & Wiring
It is working
Original, Gain & EQ Pot is Trim pot inside
Thanks.
manontheedge
Post by manontheedge »
Hi, thank you for your layout.
i Have two questions.
What diode you have used?
and what is the green component close tu taht diode?
danielzink
Completed builds: Too many: www.danielzink.com
Been thanked: 25 times
Post by danielzink »
manontheedge wrote:Hi, thank you for your layout.
I would bet the green component is a 0r resistor - or a jumper - whichever you prefer.
If you look at the layout it just continues the connection over two pads.
No guesses on the diode.
Dan
http://www.danielzink.com
MoonWatcher wrote: Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
Has thanked: 918 times
Been thanked: 656 times
Post by Manfred »
I have made a copy of the above layout to better track it using the Sprint Layout test function.
Here the traced schematic according to the layout:
I wonder what the diode resistor combination at the input is for, maybe phantom powering?
Has thanked: 312 times
Been thanked: 551 times
Are you saying that there is a function in Sprint Layout that will generate a schematic ?
How do i access this Sprint Layout "test function" ? i am using Sprint Layout V6.0
Post by Manfred »
I may have made myself misleading on that point.
No, there is no function that automatically generates the schematic it is the manual tracking of the connected tracks that you know for sure.
