Steel Panther - Pussy Melter  [traced]
dv8r601
my favorite amplifier: Peavey ranger 212
Has thanked: 382 times
Been thanked: 20 times
Post by dv8r601 »
Fast forward to 10:35 for the up close board shots.
Brad The guitologist just got his and takes one apart. Its hybrid smt thru hole, sounds sick as shit.
A500k gain
Bass(booty)c5k
Output 100k
Treble(sizzle)b10k
Opamp ca3240ez(dual bi-mos)
I did spot a sot23 n ch mosfet labeled mv near the clipping switch it also looks to have LEDs in the feedback loop
FeVeR2112
Has thanked: 43 times
Been thanked: 44 times
Post by FeVeR2112 »
Pedalpcb.com has a board available and the schematic if interested... I was asked to build one recently... meh.
toneman
my favorite amplifier: anything that works
Completed builds: meatolation, wobolation, ringolation clones, PAiA synths/modulars, dipthonizer clone, MOTM modules, pedal mods and repairs
Has thanked: 129 times
Been thanked: 28 times
Post by toneman »
Schemo doesnt seem to be posted on pedalpcb site yet. :-(
just was interested in the topology.....
inquiring minds and all that.........
Tone-to-the-Bone
toneman
Post by toneman »
Hey bugg,
i saw that u are shipping boards for the melter. any idea when the docs will be posted? thanks.
Tone-to-the-Bone
bugg
Has thanked: 45 times
Been thanked: 283 times
Post by bugg »
Yeah man, docs will be posted soon... I'm way behind again. :lol:
Been swapping some computers around all week, should be starting to play catch up very soon.
dv8r601
Post by dv8r601 »
Build Doc w/ schematic, courtesy of the Majestic Bugg,
https://www.pedalpcb.com/docs/FaceMelter.pdf
marshmellow
Has thanked: 16 times
Been thanked: 121 times
Post by marshmellow »
No crackle? That is not ok. :|
And should have used the second opamp as output for proper melting.
plush
Has thanked: 29 times
Been thanked: 114 times
Post by plush »
So... No output from this power line? What's it's purpose then?
Intripped
Has thanked: 756 times
Been thanked: 220 times
Post by Intripped »
plush wrote:So... No output from this power line? What's it's purpose then?
that's how to properly connect an unused opamp
ppluis0
Has thanked: 52 times
Been thanked: 107 times
Post by ppluis0 »
What is the need to use two resistive dividers to have two independent V/2 supply points ? :scratch:
toneman
Post by toneman »
ppluis0 wrote:What is the need to use two resistive dividers to have two independent V/2 supply points ? :scratch:
1) easier trace routing
2) less interaction between stages
3) something else(?)
Tone-to-the-Bone
plush
Post by plush »
well, yeah, but it could definitely be used for a better purpose.
rmroza
Been thanked: 45 times
Post by rmroza »
A little late to the game, but question...
In the video, you can clearly see the values on the original.
There are at least THREE differences I see between the original video footage and Buggs' schematic and board!
1. R21 1k (buggs) => 10k (actual 103)
1. R26 1k (buggs) => 10k (actual 103)
1. A100K (Sizzle) => A10k (VR3)
WHY the differences?? Is there a betterment or else in error and so should use the actual values, which are 10k, 10k, and A10k as I indicated?!?
PLEASE CONFIRM
Optical
Been thanked: 13 times
Post by Optical »
Might be a mistake but those two resistors being 1k or 10k wont materially affect anything
The sizzle control seems wrong though, maybe that capacitor should be 10n instead of 100n?
equinox
Post by equinox »
I communicated the same to Bugg directly. He's going to check it out and both ways (current and with those values) and see which is better. There may have been some differences in board between video and traced unit. We'll see.
Axldeziak
Been thanked: 18 times
Post by Axldeziak »
Here's a craptacular tagboard layout I did a couple of months ago based on the pedalpcb schematic. I drew it up with a Ca3140 single instead of a CA3240EZ. No idea if it'll work, haven't built it yet.
Axldeziak
Post by Axldeziak »
I did it for the lulz. I've been wanting to build one of these for awhile now.
Ichabod_Crane
Has thanked: 34 times
Post by Ichabod_Crane »
Pay attention, I guess that layout wrong.
This should be the verified one:
Read here to be sure: http://guitar-fx-layouts.42897.x6.nabbl ... 45063.html
rmroza
Post by rmroza »
:thumbsup
Still the open item of the values I indicated and why all these other designs (2 veros and 1 PCB by Buggs) are running on the same schematic?!?
Was there a change to the board? which is better?!??
