JHS - VCR [traced]
I haven't seen anything here or "the other forum." Does anyone have gutshots of the VCR?
The build doc on that site has a schematic (which I don't want to repost without permission). But does anyone know if the JHS really uses that FV1 chip?!?!?!?! That seems like something you'd find in a karaoke machine.
https://www.profusionplc.com/parts/spn1001-fv1
- bugg
Feel free to post the schematic.
You might be surprised to find out how many pedals use the FV-1. Although it's far from a SHARC it's certainly capable of more than just cheap karaoke machines.
PedalPCB.com - http://www.pedalpcb.com/
Interesting. They have a case study on the SHARC in Line 6 products.bugg wrote:Feel free to post the schematic.
https://www.analog.com/en/education/edu ... sharc.html
@bugg, is that in the actual JHS pedal?
- Ice-9
- Degoop Doctor
turdadactyl wrote:The build doc on that site has a schematic (which I don't want to repost without permission). But does anyone know if the JHS really uses that FV1 chip?!?!?!?! That seems like something you'd find in a karaoke machine.
The FV-1 chip is quite a powerful chip for what it does, as well as the in-built effects you can write your own code to create your own effects. This is what makes the FV-1 a powerful chip in its own right. Of course it isn't anything like a Shark processor for power but very good all the same. It's certainly not a cheap karaoke chip.
Many effects use this FV1, a couple of examples are Catlinbread Echorec, Topanga etc. Keeley plus many others including some of my pedals.Also used as the reverb in the Fender EVH5150 Valve Combo.
- bugg
Yep. The reverb and "analog chorus" are both digital algorithms coming from the FV-1. In the original the boost is just an SHO style circuit tacked on the end...turdadactyl wrote:@bugg, is that in the actual JHS pedal?
It's a tremendously noisy circuit. The clone has a lower noise floor than the original but it's not immune.
