SGFX Surf Rider III
zedsnotdead
Has thanked: 29 times
Been thanked: 51 times
Post by zedsnotdead »
So I got my hands on this little puppy.
BTDR-3 brick based reverb. Trying to trace it - would love some help, I know some of us are photoshop wizards and can make overlapping traces very easy to find.
Here we go:
Now with the brick dessoldered:
And component values:
Can you help me out with this?
Cheers!!
Has thanked: 918 times
Been thanked: 659 times
Post by Manfred »
Please, make also a shot from the other PCB-Side.
I personally put the PCB on the scanner and get the image in this way using an high resolution.
zedsnotdead
Manfred wrote:Please, make also a shot from the other PCB-Side.
There are 2 photos from the back side, with and without the brick.
Need another photo? Any specific angle?
Post by Manfred »
Only a photo from the complete solder side without backlight.
zedsnotdead
(sorry, I already resoldered the brick. This pedals not mine, so I had to put it together asap)
Here are two more, front and back without backlight.
Post by Manfred »
Thanks, but the conductors under the potentiometers are not visible.
Could you sketch in it on the image?
zedsnotdead
I've desoldered de dual-gang pot so I could take pics. Here:
Post by Manfred »
Thanks for the images.
I going to make an approximated PCB copy for tracing the circuit, but it will takes time.
Please tell me the board sizes.
zedsnotdead
Its 113mmx67mm. just measured.
Post by Manfred »
Too many missing tracks.
For this reason, it is not possible to trace the circuit.
