This is an interesting one. It is a filter with two LFOs that modulate the frequency and resonance. This is my friend's pedal and I had fun playing with it the other day. Sounds pretty cool! She currently uses it often, so I'm not sure when/if I'd get any chance to dissect it and trace, but here's some gutshots.
It appears to be a straightforward analog VCF with a couple LFOs, nothing magical or hidden going on.
Love the board design! Wish I saw fun things like this more often.
Read more about it here: https://yellowcakepedals.bigcartel.com/ ... da-machine
Yellowcake Lida Machine
- soulsonic
- soulsonic
Oh, and I will point out something you can't see in the pics. The SMD chip hiding behind the funky blue signal PCB is an LM13700 dual OTA. This would likely be used for the filter, or possibly the LFO...didn't look close enough yet to determine which.
- Nocentelli
- Has thanked: 1152 times
- Been thanked: 954 times
Thanks for this - I loved the "Knobs" YouTube demo and have considered trying to design a work-a-like, good to have it confirmed that it's 13700-based and not some fancy digital thing.
