originally posted at ilovefuzz
Infanem - The Driving Notion
- Nocentelli
- Has thanked: 1152 times
- Been thanked: 954 times
share it all over. I don't care. I'm cool with it. here is the modified version I am building as an experiment
http://www.eatyourguitar.com/DRIVINGNOTIONMOD.gif
you can build it on perf. the layout is on DIYstompboxes. not my perf layout so I don't know if it has been verified.
if you want to try it on easy mode you can support these community based team based projects by purchasing a PCB. not sure if this is ok. I checked the rules threads but could not find anything specific about selling PCB.
https://eatyourguitar.myshopify.com/pro ... ing-notion
