RnFR wrote:even with them switched, having that diode hanging off makes no sense at all. you guys are sure it wasn't connected anywhere?
I'm not saying that it definitely should be connected though, as some have guessed in the past that there was a single led in a nfb loop, which always made sense to me with the samples I have heard. so hey, who knows. maybe it's just Durham being mysterious.
I remember reading on another board that Durham had some iffy early boards made by a third party - why not use them up? Maybe the intention was to tie it in, put it on a switch or something...Might have paired up well with the sag circuit. I guess he bailed on it? If the boards were third party, maybe they were populated by someone other than him, too. In that case, it's just easier to have those components dropped in, especially if everything on the board is super common parts and values, cheap greenies, etc. Just get 'em populated per "revision 1" plans or whatever it was, and only wire up the relevant parts.
I think it was just a "production decision" that had to be made, and working in production myself for years, the time/cost-effective solutions aren't always elegant. If you are going to bury it under goop, what does it matter anyways (from Durham's perspective)?
If the proof/clues/etc. get destroyed during the degooping, it makes it hard to do anything but guess.
Someone mentioned the effect of IC1B being mild - since the sag/starve/volts thing only affects the op amp stages, maybe it contributes to that? Anyone care to elaborate?
