Analogman - King of Tone [traced]
- modman
- a d m i n
- Has thanked: 4161 times
- Been thanked: 1799 times
The mystery capacitor in another KOT gut shot
Nice find Seiche !
The 100k gain resistor, while keeping the same pot value on high-gain side, corresponds somewhat with a quote from Analogmans webstite: "It increases the DRIVE knob setting by a few numbers, in any mode. It moves the ENTIRE range higher".
According to this gutshot from madbean, the 3rd band on a stock gain side seems red (1k) to me, and not 10k as was earlier assumed:
(The carbon FILM resistor going into lug 1 (J27) on the drive pot):
- modman
- a d m i n
Not yet, scored it on facebook, I'm asking the owner of the pedal.
Thanks for that old picture -- anything that is important to the discussion in this section, please please attach it to the post. External links always go dead.
Here's a close-up of the little rascal (from the same madbean unit)
This gutshot was posted of a high gain side. Look at the resistor going into lug 1 on the drive pot here. According to the new tracing, it's should be a 100k (brown-black-YELLOW), but here it is a 1k (brown-black-RED). Now look closely on the red band... It's clearly painted on there, and you can even see the yellow under the lower edge of the red stripe
Never take the color coding for granted
Haha that’s great, thanks! So it’s official, low gain is 1k and high 100k. Nice.Bolsyo wrote: ↑23 May 2020, 17:11 This gutshot was posted of a high gain side. Look at the resistor going into lug 1 on the drive pot here. According to the new tracing, it's should be a 100k (brown-black-YELLOW), but here it is a 1k (brown-black-RED). Now look closely on the red band... It's clearly painted on there, and you can even see the yellow under the lower edge of the red stripeNever take the color coding for granted
Seiche wrote: ↑07 Jul 2018, 13:39 - the input cap is 22n on both sides
- instead of 1s1588, this uses 1n914
- output cap of the high-gain red side has an "H" painted on it, but is the same value 105 as on the yellow side.
- the feedback loop cap on the yellow side ist a weird value. 505? The red side has the usual 101=100pF.
I haven't verified all of the resistors.
So on the Pedalpcb forums, someone posted another odd value for C22 on the yellow side: 750pf.
See here: https://forum.pedalpcb.com/threads/prin ... post-27138
What do you guys think?
If you still have your unit, could you verify if the diodes in the feedback loop are connected like that (see attachment)?modman wrote: ↑23 May 2020, 15:14Not yet, scored it on facebook, I'm asking the owner of the pedal.
Thanks a lot!
- modman
- a d m i n
viewtopic.php?f=7&t=382&p=271493#p271493
here's the correct schematic - what makes you think the diodes are interlinked?
Same thread on the Pedalpcb forums, the guy has traced his KOT and found the diodes are interlinked.modman wrote: ↑19 Jun 2020, 11:50viewtopic.php?f=7&t=382&p=271493#p271493
Hey guys, that's my pedal that Boba7 posted. Both sides use the same cap in the feedback loop, marked 751. I've measured it in circuit and it's 750pf but my meter isn't the best.
I'll try and get you guys an under shot of the PCB so you can see the diodes being linked. May have traced that bit wrong myself but I'm pretty sure that's how they're set up.
- modman
- a d m i n
Thanks so much for reporting back.
Anybody tracing a unit, please make pictures and if there is a serial, mention it on the schematic. There may be differences betweens different hand built units, improvements or just mistakes by organic Japanese vegetable farmers!
i think that cap reduce noise level of the unit. The increase is significant, primal pedals 100pf, latest 750pf. Analogman could increase the value of that capacitor to 1nF and would not drastically cut high.
It's just a game!
It's just a game!
Just a game, yes, for sure!
By the way, is there a way to calculate the low pass frequency in this kind of circuit?
- FiveseveN
The formula is fc = 1/(2πRC) as usual, where R is the gain pot + the 1K or 100K "high gain" resistor. You can use a calculator like electricdruid's.
