Foxrox Hot Silicon Fuzz
warioblast
Has thanked: 10 times
Post by warioblast »
Is there any schematic floating around ?
devastator
Been thanked: 22 times
Post by devastator »
pf_fan
Post by pf_fan »
Looks like the same PCB was used for fuzz cards in CC2. This one is Si/Ge hybrid:
https://img514.imageshack.us/img514/5918/2fce3.jpg
warioblast
What's the value of the ceramic cap ? 472 for 0.0047 uF ?
pf_fan
Post by pf_fan »
Yes, it's 472. At least in this picture:
https://img293.imageshack.us/img293/5755/86523.jpg
warioblast
It should be / it is pretty close to this
Mich P
Has thanked: 59 times
Post by Mich P »
So any schem of that silcon version ?
Thanks.
Mich P.
ianZeds
my favorite amplifier: 18 Watt Baby Will
Post by ianZeds »
From Dave's site
For years people have been asking me about this..and I'm finally doing it! The Foxrox "Hot Silicon Fuzz" is the same Hot Silicon previously available as a FuzzCard for Captain Coconut 2 only. It's my take on the original high gain silicon FuzzFace with some tweaks and improvements. Foxrox Hot Silicon Fuzz uses a pair of high-gain BC109C silicon transistors, just like many of the original silicon FuzzFaces, and all of the Crest Audio reissues from the late 80's.
puppiesonacid
Been thanked: 12 times
Post by puppiesonacid »
am I a retard for thinking you can just swap out the germaniums for silicon as long as the pinouts are the same?
warioblast
puppiesonacid wrote:am I a retard for thinking you can just swap out the germaniums for silicon as long as the pinouts are the same?
But you also need to reverse the electrolytic capacitors.
What puzzles me the most is the location of the ceramic cap. I put a NPN "Mervin" on the breadboard; with the typical 33k resistor from Q1's collector to +9V.
I tried to put the 472 cap between Q1's B & C, Q2's B & C, across the 100k... but the high end roll-off was too big.
Gila_Crisis
Been thanked: 124 times
Post by Gila_Crisis »
i don't know why, but i'm supposing that the 4.7nF cap is going somewhere near the input side.....
maybe something like this:
of only there were a better pic of the pcb...
JimiB
my favorite amplifier: AC30
Been thanked: 5 times
Post by JimiB »
That dosent make any sense. If the cap was across the 100K, it was from Q1's base to Q2's emitter. I do think that would dump alot of high end.
wilkins
Post by wilkins »
this seem on [url=http://analogguru.an.ohost.de/001/schem ... p_JH-2.gif]JH-2[url] C2, put the 4700pF after the input capacitor before the Q1 / R6 & C4.
warioblast
You got me wrong.
I meant I tried to put the 472 cap in different places:
_ between Q1's B & C,
_ between Q2's B & C,
_ across the 100k...
warioblast
I've tried that too but it made the circuit noisier.
pf_fan
Post by pf_fan »
Maybe those pics will be helpful... somehow
http://www.megaupload.com/?d=ELNBOD8D
Barcode
Been thanked: 32 times
Post by Barcode »
you only need to switch the cap polarity if you are switching to/from positive ground, and you only have to do that if you are subbing in NPN for PNP transistors. If you are using the same type (NPN, PNP) as the exisiting transistors, no change is needed in polarity of anything.
wilkins
Post by wilkins »
You got me wrong.
maybe use 100pF and justs put on Q2, same as the mod. of Axis Fuzz.
WhiteKeyHole
Has thanked: 24 times
Been thanked: 220 times
Post by WhiteKeyHole »
I think you're kind of missing the point. He's trying to figure out where the 4.7nF capacitor might be in the circuit.
