Chunk Systems - Brown Dog Fuzz
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 70 times
- Been thanked: 66 times
- Contact:
I'm also interested in schem or gutshots of anything from Chunk Systems : Brown Dog, Agent 00Funk Mk1 & Mk2, or the new Octavius Squeezer (just dreaming for the last one ...)
- Bernardduur
A friend of mine has one; I'll try to get him to borrow it to me
That would be great!Bernardduur wrote:A friend of mine has one; I'll try to get him to borrow it to me
There are some gutshots here but not enough to trace out the circuit: http://bassfuzz.com/2009/04/02/fuzz-rev ... ss-fuzz/5/
- invalidcd
Looks to me like a moded Red Llama or a moded Big muff depending on the ic because i only see one ic its either a LM3046 ie(Big Muff) or 4069UBE ie(Red Llama), I also could be completely wrong in which case im a dumb ass
Looking at the traces on the back, it doesn't look to be that complicated of a circuit. I don't see any diodes so it's probably not any sort of Big Muff-like circuit. I can see the IC (two op-amps?) and FET or BJT transistor. Not a whole lot of caps and the ones I see are electrolytics.
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Contact:
Maybe i'ts just my imagination, buy after some image manipulations i read "TL074CN" on the chip.
If it's not an opamp BigMuff (because of the lack of (visible) diodes), it might well be something original ...
- invalidcd
no, thats impossible, you my friend are a dreamer and the world really is flat.JiM wrote:Maybe i'ts just my imagination, buy after some image manipulations i read "TL074CN" on the chip.
- Greg
It's got 14 pins so it's not a 4049 anyway.JiM wrote:Maybe i'ts just my imagination, buy after some image manipulations i read "TL074CN" on the chip.
- invalidcd
is it at all possible that the diodes are on the pot board ..... it just seems weird , an op-amp fuzz without diodes, maybe it uses mosfet for clipping
A bit strange, isn't it? Hopefully Bernardduur can come through with some better gutshots.invalidcd wrote:is it at all possible that the diodes are on the pot board ..... it just seems weird , an op-amp fuzz without diodes, maybe it uses mosfet for clipping
- Bernardduur
Shame; he had the Brown Dog for a while but sold it. He still got the Agent 00FUNK which I took apart and placed on the forum. He misses his unit though so I think it'll be added to his rig pretty soon.......
(well, I hope so )
(well, I hope so )
- chicago_mike
Theres an Agent00Funk here?????
WHERE!!!!!!!!!!!!!!!!!!!??!?!?!?!?!?!?!?!?!?!??!
Skyline FX 2013
- Bernardduur
LOLchicago_mike wrote:Theres an Agent00Funk here?????
I didn't put it in the 'boutique' section as I don't find it THAT boutique..........
Check
- chicago_mike
I dun used'ed the search'm tool.
Skyline FX 2013
- chicago_mike
Perhaps its just a modded brown source with a noise gate of some kind?
Skyline FX 2013
I have one -- the early (and best) version that is slightly larger and more tweakable than the later or current production. I won't have time until the weekend to take it apart and give you guys some gut shots.chicago_mike wrote:Theres an Agent00Funk here?????
I bought it because it sounded just as good as the Lovetone Meatball, and is easier to use as well, not to mention much smaller.
- chicago_mike
Kewl.
Skyline FX 2013
- chicago_mike
Desperately wanting more gut shots and a possible schema bumpy bumpy bump.
Skyline FX 2013
