Xotic - RC Booster [traced]
- Goop_buster
Thanks azza
Hey there seem to be a 470 ohm "mojo" CC resistor in there Is that a stock component or a mod
Interesting to see that the board is a bit different from that in the AC.
Perhaps just another board revision?
I'm including one mojo resistor in all my builds now. The question is: what's the best place for you mojesistor? Is it in the feedback loop of your TS? Or in the tone control of your Muff? Or on the collector of your pnp germ?
Enlighten me!
Enlighten me!
- Goop_buster
madbean wrote:I'm including one mojo resistor in all my builds now. The question is: what's the best place for you mojesistor? Is it in the feedback loop of your TS? Or in the tone control of your Muff? Or on the collector of your pnp germ?
Enlighten me!
At least we know that Xotics opinion is that the correct place for CC-mojo is in series with the signal before the output. There was a similar CC resistor at the same position in the AC-booster too.
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
Yep -rolls off the extreme high end due to the lousy carbon granular construction - also adds noise too.At least we know that Xotics opinion is that the correct place for CC-mojo is in series with the signal before the output
So, the million dollar question is: what should we use small caps for?bajaman wrote:Yep -rolls off the extreme high end due to the lousy carbon granular construction - also adds noise too.At least we know that Xotics opinion is that the correct place for CC-mojo is in series with the signal before the output
The better answer I can find is: maybe they didn't care much about the high end roll off, maybe they were just after that pinch of extra noise.
About the best place for the CC mojo, it's probably as close to the input as possible, so you get the most gain over that small noise and turn an ordinary distortion box into a noise box, or as a true booteeker would say, "an effect on its own", "tone nirvana unheard before" or "(add your favorite Lovepedal or Zachie description here)".
- Silent Fly
Enjoy
- culturejam
- Silent Fly
It would be even more awesome if someone draw a schematics from my pics/valuesculturejam wrote:Awesome.
Just added this to the White List
- soulsonic
Great job, man!
I'll get to work drawing up the schematic.
- Silent Fly
Thanks for your kind wordssoulsonic wrote:Great job, man!
...and I look forward to see the schematicssoulsonic wrote:I'll get to work drawing up the schematic.
- The Rotagilla
Correct me if I'm wrong but don't we already have a schematic and layout?Silent Fly wrote:Thanks for your kind wordssoulsonic wrote:Great job, man!
There are two other threads addressing this pedal,
viewtopic.php?f=7&t=262
viewtopic.php?f=7&t=843
And in a recent thread, regarding low output from the AC, there was a schematic linked which had the changes to make it an RC.
http://schematic.exteen.com/xotic-rc-booster-ac-booster
- soulsonic
Yes, but that schematic and project is inaccurate to the RC Booster. As you can clearly see in the photos, it doesn't even include the correct number of diodes, which surely has a huge impact on how it distorts.
Fuzzer wrote:There are two other threads addressing this pedal,
- Spazzmatazz
it's two side pcb?
I was recomended to build one of this.
what's the difference between the AC and the RC?
I want a clean booster.
- soulsonic
Yes, two sided. The main difference between this and the AC is that the RC has less gain and additional diodes in the feedback loop which raise the level at which limiting occurs. It also does it's limiting symmetrically, in contrast to the AC which does it asymmetrically. The low frequency bandwidth is wider as well.Spazzmatazz wrote:it's two side pcb?
It looks like it is a clean boost - certainly cleaner than the AC.
- briggs
- Silent Fly
You may want to check the Xotic web site. You can find specs and videos.Spazzmatazz wrote:[...]
If you look for a clean booster the RC is closer to what you want. You can also add a switch to remove the clipping diodes for an extra-clean sound.
Sure, I was just trying to reference every bit of data that is around the forum, so they can be merged and after that, emphasize on the correct info.soulsonic wrote:Yes, but that schematic and project is inaccurate to the RC Booster. As you can clearly see in the photos, it doesn't even include the correct number of diodes, which surely has a huge impact on how it distorts.
- soulsonic
Here is the schematic:
