Xotic - AC Booster [ goop-alarm ]  [traced]
guitarquiz
Post by guitarquiz »
Realy Realy good job I think it was same as TS? + Mod Treble and Bass?
The Rotagilla
Been thanked: 59 times
Post by The Rotagilla »
Well the AC has finally been knocked off my board as my main OD. I'll get to work on labeling the pads for the off board connections. I should be able to have it done by next weekend. If there's anything not clearly indentifiable in the previous pictures, please let me know and I'll confirm.
The Rotagilla
Well next weekend is here and I've made little progress. As I stated earlier, I destroyed the factory IC installing the socket so I contacted Xotic and got a replacement. The ID numbers were sanded off the replacement as well, but not completely. I was able to make out the following...
45--D
RC
I'm going to guess the stock IC is a JRC 4558D. When I installed an extra 4558D I had, it sounded the same as the one they sent me. I'd say one more question answered.
lautmaschine
Post by lautmaschine »
JHS, your links don't seem to be working. Can you fix them?
JHS wrote:
REV: A
... a bit closer to the org. thing but w/o trannie and IC specs useless as before.
JHS
gtrwrks
Post by gtrwrks »
I increased the input cap on my AC to .056uF for more meat and increased the pico cap in the IC's FB loop to 220pF for a little more rounding. I also lowered the last resistor in line to 100 Ohms (CC) for even greater mojo.
Lovepedal Detective
Post by Lovepedal Detective »
Very Cool. Thanks for the work on this one.
LP
The Rotagilla
Long overdue and I do apologize. Photo notes -
1) There are three pads under the 1uF NP for the Volume control.
2) I'm going to revise my statement about the stock IC. After staring at the replacement Xotic sent me under a bright light until my head hurt, I'm going to say it might be a JRC4557D.
3) Direct Photo Link
I have not compared this to the existing schematic. Hopefully someone has enough info now to do a layout.
Location
New Brighton, Christchurch, NZ
Has thanked: 466 times
Been thanked: 1704 times
nice hi res picture Rota :wink: :D
gtrwrks
Post by gtrwrks »
Has anyone (here) completed the AC Booster schematic? The 'RotaXotic' Drive that is up is lacking a few components that are on the circuit board - not quite completed.
A better understanding of what each component on the board is responsible for would greatly help personalization of this circuit.
Thanks.
The Rotagilla
gtrwrks wrote:Has anyone (here) completed the AC Booster schematic? The 'RotaXotic' Drive that is up is lacking a few components that are on the circuit board - not quite completed.
Thanks.
First page of this thread contains a component labled pic. :wink:
ranmusic84
Post by ranmusic84 »
hi. i'm ranmusic84 from Japan.
sorry for my bad english.
i made AC booster schematic from Rota's photo and ts-808 schematic.
if there's some mistake, point them.
i have no confidence that the transistors are 2sc1815. bet this transintor are used in BB preamp.
https://i251.photobucket.com/albums/gg29 ... OOSTER.jpg
my favorite amplifier
Stopped using amps mostly...
Has thanked: 89 times
Been thanked: 291 times
ranmusic84 wrote: if there's some mistake, point them......
Hello. Welcome to the forum!
I see a small mistake. There should be a resistor connected between Q1 Emitter and common ground. Without this, there will be no sound.
Thank you for your work.
ranmusic84
soulsonic wrote:I see a small mistake. There should be a resistor connected between Q1 Emitter and common ground. Without this, there will be no sound.
Oops! thank you for telling!
I've fixed the mistake and updated the file.
https://i255.photobucket.com/albums/hh12 ... OOSTER.jpg
The Rotagilla
Welcome and nice work.
I'm fairly certain the op amp is a JRC4557D. Is your schematic a Tube Screamer that's been AC Booster'd or are you fairly confident that it corresponds to the photos? Thanks again.
ranmusic84
Nice to meet you Rota!
First. I copied the circuit printed on back side to top one.
https://i255.photobucket.com/albums/hh12 ... _84/AC.jpg
and traced that with ts-808 schematic.I've heard AC Booster is similar to TS-808
tone,gain part and some values are different but almost all the circuit is the same.
and I found a small mistake on wiring photo.
I think Output could be input.
thanks.
ranmusic84
gori
Post by gori »
Hello, everybody
I think about Vref1 and Vref2 in this way.
If there is a mistake, please teach it.
JHS
Post by JHS »
The bias supply is correct. The caps are 10uF and Vref1 is only used for biasing the input trannie.
JHS
ranmusic84
hello! Mr. Gori and Mr. JHS!
thanks for pointing my mistakes!
i've fixed the schematic again.
JHS
Is there any differences on main signal circuit from original one?
ranmusic84
i'm really sorry for my mistakes.
Mr.gori told them and i've fixed them.
-add 10uF in bias circuit
-change emitter of output transistor to GND
lynessmy
Post by lynessmy »
If my trace is correct, the bias of output transistor is connected to Vref2....
