BJF - Honey Bee Overdrive degooped  [traced]
Has thanked: 4411 times
Been thanked: 2139 times
The Honey Bee....
restored pictures...
The IC has been sanded, but not properly and the lettering is very tiny, but I think
CA3130
I have never seen such diversity in resistor in any electronic device: a red carbon comp 1/2W, carbon film 1/4W and 1/8W, three different type of metal film (bright blue, dark green, light green)... :hmmm:
Now are you planning to do a special order, or will you just use the crap lying around your workbench?
:wink:
Top left
Top left
top right
top right
bottom right
bottom right
bottom left
bottom left
Sorry, I got sidetracked this evening.
Black diodes are 1N4007
Ceramic disc cap on the ic is 100pF
Transistor seems to be more properly sanded than the IC: ?
Red wima's 2 x 22nF and 1 x 47nF
Blue wima in parallel with 47k is 4,7nF
here's a pic, but more tomorrow, have to get to bed now
Center lug of the Nature pot is connect to ground on the input jack.
On of the outer lugs goes to the green WIMA capacitator, the other side of which was connected somewhere on the component side. It got disconnected during degooping because it was just floating in the goop.
BJF's improvised layout requires and presupposes a goop covering, otherwise this box would keep working for 2 gigs straight.
I think there is no other solution that to desolder the green wima's.
Honey Bee wiring connections
Fet voltages, facing the transistor lettering (that's sanded off now)
source 9.1V
8.51V
7.75V
8.53V
Have to bump this to the top.
These are the degooping pictures of the Honey Bee, first published for the contributors of the Tracer's Fund, as promised. There are a lot more to come as well as a preliminary schematic that left everybody utterly disinterested.
more later
Ghandi
Been thanked: 28 times
Post by Ghandi »
oh my man, there it is!
thanks for all your time degooping it modman!
lookin' forward for the schematic!
lolbou
Has thanked: 308 times
Been thanked: 225 times
Post by lolbou »
modman wrote:a preliminary schematic that left everybody utterly disinterested
Nothing really new then? Anyway, it's a good thing to have this opportunity... Thanks a lot to you and to all the contributors! :applause:
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
SPeter
Been thanked: 80 times
Post by SPeter »
Great! Many thanks!!!
:applause: :D
loves_guitar
Post by loves_guitar »
modman wrote:There are a lot more to come as well as a preliminary schematic that left everybody utterly disinterested.
Thanks for all of the hardwork!!
I wonder if de-gooping pedals is like revealing magic tricks - once you know how it is done, the magic is gone.
jbrew73
Post by jbrew73 »
i cant wait to see whats going on in the honey bee. i read somewhere there is a bass version of the honey bee but cant remember what the name of that pedal is.
mistermikev
my favorite amplifier: deville 4x10
Completed builds: -modded big muff (russian) w 6way rotary selecting clipping dioes/emitter lift/true bypass/new pots.
-modded ts8 with diodes, 4558chip, 10k/100ohm resistors
-byoc analog chorus-built a two true bypass loop/order switch
-tube crusher = tube screamer + orange squeezer
-booster
-nurse quacky
etc
Post by mistermikev »
my interest has never been more peaked.
thanks for doing the de-goop which appears to have been somewhat similar to an archeological dig.
I have all the parts on the board populated... so all the real work is done... now I just have to get it working.
Whoismarykelly
Post by Whoismarykelly »
These photos make an Effector 13 pedal look like a rock solid barber build. How bout those years of lying about all-discrete circuits too...
Whoismarykelly wrote:How bout those years of lying about all-discrete circuits too...
So you guys really want to see the IC? :mrgreen:
I made a copy of the original thread for the Tracer's fund, so the rest of the pics will be above, as all threads are organized chronologically...
Ghandi
Post by Ghandi »
urr,
the build quality isn't that nice, that's for sure!
oh yeah and I can happily remember those old DISCRETE DAYS!
*I CAN SEE A LIAR, SITTING BY THE FIRE*
shame on you björn!
the FOLK DRIVER looks way more creative that this dirty little thing!
so what IC is that?
let me guess, a CA3130?
picassochild
Been thanked: 8 times
Post by picassochild »
I see BJF style of wiring etc... which isn't the best. But now I think as thought before that Bjorn is trully genius! Ghandi, I saw bunch of RAT mods and have never seen any mod for RAT with CA3130 or any od/dist fx with it. It's very easy to say "let me guess what IC is there" now ;)
estragon
Been thanked: 11 times
Post by estragon »
Speaking of guessing, the board pictures pretty much suggest the HB could be "Dyna Green Distortion"--a variation of the Dyna Red Distortion. Check the DRD schem here:
https://www.freestompboxes.org/viewtopic.php?f=7&t=5502
The circumstantial evidence:
1) The same author
2) The statement about disinterest in the circuit after starting to trace it
3) Two green LEDs v/s two red LEDs
4) Two back to back 1N4007 diodes in both
5) A lonely 1N4007 and a lonely Zener-like diode in both
6) A single 8 pin IC in both
7) A single FET or TRANSISTOR or TO-92 device in both
8 ) The same number and function of the controls in both
9) Approximately the same complexity in terms of the number of resistors and capacitors. In particular, the HB has 5 electros while the DRD has 6; nonetheless one of the electros in the DRD is 0.47uF, so it could be perfectly implemented with a non electro cap in the HB.
10) There is a statement in the third post of the thread linked above suggesting the DRD is a variation on the HB. At that time there was not much tangible evidence, but these latest pictures certainly support that.
Ghandi
Post by Ghandi »
then clay jones is a genius too...
IMO just stickin' a different op-amp in there doesn't make you a genius.
he may have some very good ears...
but remember all the bullshit about the honey bee, dyna red etc. using only discrete stuff...
pretty tuff lie, that's my point!
