Emma - Reezafratzitz [ goop-alarm ]  [traced]
roseblood11
Has thanked: 349 times
Been thanked: 305 times
Post by roseblood11 »
Does someone have a veroboard layout, esp for the new version?
kupervaser
my favorite amplifier: MATAMP
Completed builds: ZVEX Fuzz Factory, Crown Super Fuzz, Tube Screamer 808, ZVEX Wooly Mammoth, Way Huge Swollen Pickle, DIEFET, OCD
Post by kupervaser »
Built this thing last week.
Didn't work in the first place, but later on I spotted a connection between traces due to a bad etch. After the fix it started working. Everything works well, sounds great, however i consistently wired all of the 4 pot meters backwards.
Here are some pics and will post some sound samples later.
kupervaser
thn.technik
my favorite amplifier: Laney
Completed builds: Shred master, Tube screamer, Reezafratzitz, SansAmp GT2, RAT, Okko Diablo, Metal Simplex...
Been thanked: 44 times
Post by thn.technik »
Hi guys,
I do it again hehehe... it's my new THN Reeza :D
Housing it's a box from USB stick, no foot switch bcoz is always standing at top of amplifier( BTW it's my own production, ECL86, 3W for home use)
I found 2 pcs OKI MSN4069RS IC in my old video recorder, its work much better than MCY74049 which I use before, so I change it also in my old Reeza, now is clearly difference in bias potentiometer.
BTW I get question about potentiometer names, so once again schematic with descriptions
And my small and simply amplifier 8)
Regards!
P.S.
Don't waste you time and build your own THN Reeza, it's great fun with this box :thumbsup
soonerrob
Post by soonerrob »
Ive built 2 of these from the THN project... 1 from the THN pcb layout and one of my own from the THN schematic... both circuits are dead.
both audio signal die at pin 1 of IC... not sure what is wrong.
thn.technik
soonerrob wrote:Ive built 2 of these from the THN project... 1 from the THN pcb layout and one of my own from the THN schematic... both circuits are dead.
PCB image is in mirror, so maybe try to turn up/down your IC 4069,
notice also that you need to have UB - unbuffered version of CD4069
soonerrob
Post by soonerrob »
OMG... you're absolutely right technik.....
Hope I didnt fry my IC. :)
soonerrob
Post by soonerrob »
Reeza is workin great.. thanks Technik... the IC was reversed. fixed.
Nicht Bernd
Has thanked: 98 times
Post by Nicht Bernd »
thn.technik wrote:I found 2 pcs OKI MSN4069RS IC in my old video recorder, its work much better than MCY74049 which I use before, so I change it also in my old Reeza, now is clearly difference in bias potentiometer.
do you know where to buy the OKI?
thn.technik
Hi, I have no idea where you can buy it, I just disassemble my old AKAI tape video recorder.
BTW all parts in my second Reeza are from this recorder :wink:
I find only one shop with this part:
http://www.accordtech.com/4069RS.html
Throbb7
Post by Throbb7 »
I have used the 74HCU04 14 pin chip in distortion circuits designed for the 4049ube and they work very well. I'm not sure if the pins match up. ;)
http://pdf1.alldatasheet.com/datasheet- ... CU04N.html
XoB
Post by XoB »
thn.technik, why you won't use of classic fender of marshall tonestack. If we'll take kind of fender tonestack we'll get more mids deep & possibility to get some freq distribution
thn.technik
XoB wrote:thn.technik, why you won't use of classic fender of marshall tonestack. If we'll take kind of fender tonestack we'll get more mids deep & possibility to get some freq distribution
main problem with "classic fender" tone stack is that if you put 10V RMS at input then you get 1V RMS at output, so you need to do x10 amplifier for signal.
biliousfrog
Completed builds: Zen Drive, Fuzz Factory, Really Cheap Compressor, D*A*M 66, Klon Buffer, CryBaby mods, Boss TR2 mods, Various loops and switchers, DOD250, Fulltone Bass Drive, MXR Bluebox mods
Been thanked: 8 times
Post by biliousfrog »
I just wanted to gloat a little - bought a mk1 for £40 inc. postage. Sounds great so far, really looking forward to cranking it through a decent tube amp at rehearsal.
It seems very well voiced, the tone control (just one on this) is perfect at 12 o'clock, same with the volume and bias...in fact I'd be happy just running everything at noon.
IvIark
Has thanked: 561 times
Been thanked: 579 times
Post by IvIark »
Forgot to post this:
Modified version with additional Bass and Mids controls:
Nefi_fatobene
Has thanked: 10 times
Been thanked: 5 times
Post by Nefi_fatobene »
Nice Job Guys!!! :applause:
asatbluesboy
Has thanked: 38 times
Post by asatbluesboy »
Loved the "circuit window". Why don't ALL pedals have that? Would save us a lot of trouble... :mrgreen:
...collectors together and emitter to base? You're such a darling...
ton.
juozasu
my favorite amplifier: JCM800, Soldano SLO100
Post by juozasu »
mictester wrote: The original Emma board is MUCH bigger - and now you can see why.
The problem is not that components are close to each other, but it has a very problematic ground. PWR GND and SIGNAL GND, there is no "star GND" point.
TubeHugger
Completed builds: BIG muff green version
JCM800 tube Preamp in a box
steampunk kitten ("original" recipe tube overdrive pedal)
angry kitten tube amp (5W EL84 evil little gainer)
JCM800 2204 replica amp
wampler triple wreck clone
reezafratzitz clone
Bsiab III
Crunchbox clone
Post by TubeHugger »
here's mine.
my first etched PCB.
and second wrong IC mirroring :slap: (its on the back of the board)
did the thn.technic layout.
man it was dark sounding.
changed the low pass filter after the tone control and voila
it sounds great now.
i used 470K pots instead of 500K.
could this make a big difference on the sound? :scratch:
"JMP it's a good place to be" - Big Bob
commathe
Been thanked: 7 times
Post by commathe »
That bias control is interesting. Is it just starving the op-amps and preventing them from amplifying the whole wave properly?
