Rockbox - Boiling Point  [traced]
Pyr0
Has thanked: 22 times
Been thanked: 19 times
Post by Pyr0 »
bencoles wrote:IS HARALDS VERO WORKING??
Yes, it works fine, I just built one a few weeks ago.
hotguit
Post by hotguit »
Hi everybody
Here i attached the layout and the pcb of the Boiling Point
it is BUILT AND VERIFIED. It works perfectly and sounds as it should.
It fit is a small Eddystone enclosure.
Have fun
bye
hot
render file
render file
pcb - resize it before printing
PnP REV 1.gif (6.77 KiB) Viewed 3002 times
dromilious
Post by dromilious »
hotguit wrote:Hi everybody
Have fun
bye
hot
Thanks for the layout.R12 is 1 k? or 1 ohm or something else?
also the CC notes for the resistors what mean?Thanks
bencoles
Post by bencoles »
CC= Carbon Comp i think??
Been thanked: 909 times
BP is traced? When? Cool :thumbsup
dromilious
i guess it is carbon comp and r12 is 1k like the vero.
beedotman
Has thanked: 402 times
Been thanked: 394 times
Post by beedotman »
sinner wrote:BP is traced? When? Cool :thumbsup
We're waiting for Your vero for BP, Sinner!
Those 100nF filtering caps here and there, shouldn't make significant difference, right?
@askwho69 - I'm sure B.Man was just sarcastic, but... who knows ;)
beedotman
Post by beedotman »
askwho69 wrote:i think that 100nf are just power filtering no sound difference :D i made mind using GGG's layout and it work :D
I know, mate.
I'm just wondering if there's any justification for placing them everywhere around...
hotguit
Post by hotguit »
Hi
R12 is 1K CC (carbon composition)
That pcb works perfectly
bye
hot
andregarcia57
Has thanked: 74 times
Been thanked: 111 times
Post by andregarcia57 »
Barcode wrote:FINALLY here is that dual layer board I used. It's verified. Don't forget to make the vias.
Kelvin.pdf [206.6 KiB] schematic ok?
IvIark
Has thanked: 562 times
Been thanked: 586 times
Post by IvIark »
This is verified for anyone wanting a vero layout
andregarcia57
IvIark wrote:This is verified for anyone wanting a vero layout
ok, thank you!
do you have schematic?
IvIark
Post by IvIark »
andregarcia57
alexirae
Post by alexirae »
Hi guys,
Someone know how can I compensate the volume drop when you change the switch from middle position to any of the diode clipping positions?
I was thinking about a volume reduction in the middle position but I don't know how.
Any suggestions?
candletears7
Been thanked: 5 times
Post by candletears7 »
Alexirae,
That volume drop occurs because in the other positions the diodes clip the signal and the output volume. In the centre 'off' position, you have no clipping, so the opamp is increasing the signal dramatically with nothing clamping it later. So it sounds very loud compared to the other settings.
Here's what I would do to get some relative volume persepctive going on in your 3 clipping diode options.
Replace the on-off-on switch with an on-on-on. This means each throw much select a clipping option, as opposed to having the centre 'no clipping at all' option.
position 1) the standard 3x1 silicon diode array as shown in Iviark's vero (thanks for that too mate!)
position 2) your 2 LED's. (LED's are very open sounding, almost like no clipping if the gain is down and the volume is up)
position 3) the classic Tubescreamer 1x1 symmetrical silicon diode array.
In fact, you can experiment with diode clipping on this switch. Any combination you want.
Just Google 'Landgraff style clipping mods'. The Rockbox pretty much just takes off on the L'DO style clipping mods.
Barcode
Been thanked: 32 times
Post by Barcode »
alexirae wrote:Hi guys,
Any suggestions?
It's the nature of the beast. When you switch clipping diodes, it's going to affect how much the signal is being clipped, and thus how much headroom the signal has. When the signal is clipped more, you get more gain but less volume (mostly, this is an oversimplification).
If you wanted the volume the exact same in all positions, you'd either need some serious switching that switched in different volume controls or you'd have to build some sort of gain compensation circuit that changed based on the position. Needless complication. How often are you going to be change the clipping in the middle of playing?
Syder
Post by Syder »
Have fun
bye
hot
Hey, I used your layout and I found 2 mistakes, so I don't think yours is sounding as it should, since you have a 0.0022u (2n2) input cap instead of 0.022u (22n) and you also have a wrong connection for the 10k resistor at the feedback of the first opamp. You should replace R5 with a jumper and throw the 10k resistor from the board to lug 2-1 of the gain pot, or simply omit the resistor with no tonal change.
Thanks.
Pyr0
Post by Pyr0 »
Have fun
bye
hot
Thanks.
I'm just building one using this layout, so good catch on the input cap.
It doesn't matter what side of the gain pot that 10k resistor is on, it will work the same.
