Page 1 of 3
D*A*M Fleshhead
Posted: 18 Jan 2010, 12:18
by mcaviel
A 10 pedal batch listed in D*A*M ebay Store,
heres the pics form the DAM forum:
Re: D*A*M Fleshhead
Posted: 18 Jan 2010, 15:02
by Spewbag
SolaSound????
Re: D*A*M Fleshhead
Posted: 18 Jan 2010, 16:35
by phibes
Easy one. MKII, the fuzz pot is wired at max on the board (1K) with a tone/filter (flesh) pot in it's place. 470R was bumped to 820R. Name kinda creeps me out, reminds me of those flesh lights!
Re: D*A*M Fleshhead
Posted: 01 Apr 2010, 17:39
by plmr5181
By the way, this circuit sounds Great!! MKIIish sounding with filter control!
Re: D*A*M Fleshhead  [traced]
Posted: 01 Apr 2010, 19:27
by phibes
Not 100% percent but this is how it looks from the gut shots on the net. Buddy above said it sounds good so what the hell. Go nuts!
Re: D*A*M Fleshhead
Posted: 01 Apr 2010, 20:24
by blanik
phibes wrote:Not 100% percent but this is how it looks from the gut shots on the net. Buddy above said it sounds good so what the hell. Go nuts!
funny they made the output cap "selectable" i always prefer when it's the input one that's like that, it gives a wider range of sounds...
Re: D*A*M Fleshhead
Posted: 02 Apr 2010, 04:29
by phibes
This be how I see it.
Re: D*A*M Fleshhead
Posted: 02 Apr 2010, 18:01
by plmr5181
I've tried both 100KB and 100KA for the volume pot and find that the 100KB has a better feel than the traditional 100KA thats used in the MKII circuit. i would definatley recommend using the 100KB. phibes, any thoughts on the volume pot taper? what do u think is in the original fleshhead?
Re: D*A*M Fleshhead
Posted: 02 Apr 2010, 21:29
by phibes
My guess would be Linear.
Re: D*A*M Fleshhead
Posted: 02 Apr 2010, 22:18
by IvIark
Just noticed that I put the first 10K resistor in before the input cap so it would be acting like a 10k pulldown resistor. I've altered the layout on Photobucket so if you refresh the page you should be able to download the latest version in my post above.
Re: D*A*M Fleshhead
Posted: 05 Apr 2010, 01:30
by candletears7
This wee beastie is actually quite neat!
I have been comparing the schemo above to the 3 and 2 knob bender shematics over at Fuzz Central.
In my limited awareness it looks to me that the Fleshhead is a MKII with the Fuzz pot replaced by that 1k resistor to ground off Q3, incorporating the Tone control section of a MKIII, with a larger cap value (6.8nf VS. 2.2 nf).
I know I'm stating the bleeding obvious here, but for someone who has been umming and ahhing about whether to build a MKII or MKIII for the first time, it would appear that this straddles the fence quite nicely.
Re: D*A*M Fleshhead
Posted: 06 Apr 2010, 12:14
by neoflox
So which layout is verified? :block:
Re: D*A*M Fleshhead
Posted: 06 Apr 2010, 16:28
by phibes
neoflox wrote:So which layout is verified? :block:
The one I posted above is good to go. Personally, I would use the wider pitch stripboard for it. It wouldn't be hard to convert a MKII pcb for this too.
Re: D*A*M Fleshhead
Posted: 06 Apr 2010, 20:19
by Whoismarykelly
phibes wrote:The one I posted above is good to go. Personally, I would use the wider pitch stripboard for it. It wouldn't be hard to convert a MKII pcb for this too.
Is there any place to get that wider pitch stripboard outside of making a huge order at allied? I have been trying to find it for my pedals and that seems to be the only place to get it in the states.
Re: D*A*M Fleshhead
Posted: 06 Apr 2010, 21:43
by neoflox
Someone want to make a recommendation for an equivalent transistor? :blackeye
Re: D*A*M Fleshhead
Posted: 06 Apr 2010, 22:46
by Whoismarykelly
neoflox wrote:Someone want to make a recommendation for an equivalent transistor? :blackeye
Anything that would work in a MKII should work here. Ideally you would want a set that will bias up properly with those values.
Re: D*A*M Fleshhead
Posted: 07 Apr 2010, 03:40
by candletears7
I have used Matsushita 2SB172's in a kit Tonebender build and in a few Treblebooster builds, and they have worked quite nicely for me. :thumbsup
Any interest or any point in a group buy for some of that there mojo-rific wider spacing vero?
I know that I would be up for some.
Re: D*A*M Fleshhead
Posted: 07 Apr 2010, 05:04
by RnFR
i'd pick up some. why don't you start a new thread.
Re: D*A*M Fleshhead
Posted: 07 Apr 2010, 11:15
by Electric Warrior
That looks great. What software did you use to draw the schematic?
Re: D*A*M Fleshhead
Posted: 07 Apr 2010, 13:17
by candletears7
I would, but I have no flipping idea where to get it, but I could check it out. I'm in Australia, so maybe I could find an alternate supplier for over here. No promises though! Weight wise I'm assuming postage over to the USA or wherever would be reasonable, it's not like I'd be putting a transformer in the mail. I'll have a sniff around.
